Page 1 of 3 1 2 3
Rocker arm geometry on a 440 #1414007
04/02/13 10:32 PM
04/02/13 10:32 PM
Minneapolis, MN
moparguy Offline OP
moparguy  Offline OP
Minneapolis, MN
I picked up a set of Harland Sharp roller rocker arms for my 440. It looks like the roller may be abit far forward on the valve tip. Will this be alright or is there some way to fix the geometry? There is nothing fancy about my set up. i am running a 545 lift cam however.
Re: Rocker arm geometry on a 440 [Re: moparguy] #1414008
04/02/13 10:38 PM
04/02/13 10:38 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
shim up the shaft. that will move the scrub pattern more towards the center.
Re: Rocker arm geometry on a 440 [Re: moparguy] #1414009
04/02/13 10:39 PM
04/02/13 10:39 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Shim up the rocker arm shaft?
Brian
Re: Rocker arm geometry on a 440 [Re: '72CudaRacer] #1414010
04/02/13 10:57 PM
04/02/13 10:57 PM
Minneapolis, MN
moparguy Offline OP
moparguy  Offline OP
Minneapolis, MN
For some reason I was thinking backwards and thinking that if I shimmed it up it would get worse. Thanks guys!
Re: Rocker arm geometry on a 440 [Re: moparguy] #1414011
04/02/13 11:02 PM
04/02/13 11:02 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
You are right, shimming the shaft up will move the contact farther to the outside of the valve tip.
For me...........I'd leave alone, it will be ok.
Re: Rocker arm geometry on a 440 [Re: AAR-B4] #1414012
04/02/13 11:16 PM
04/02/13 11:16 PM
Washington
skrews Offline
skrews  Offline
Washington
Shimming the shafts up will make the problem worse. Lash caps will improve the situation, but may not fit your retainer/keeper combo.
Re: Rocker arm geometry on a 440 [Re: skrews] #1414013
04/02/13 11:24 PM
04/02/13 11:24 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Are the contact patterns shown in the pictures of a full sweep on the cam lobe?
Re: Rocker arm geometry on a 440 [Re: StealthWedge67] #1414014
04/02/13 11:25 PM
04/02/13 11:25 PM
Minneapolis, MN
moparguy Offline OP
moparguy  Offline OP
Minneapolis, MN
Yes Stealthwedge, I marked it and turned the engine over 2 times to get a good rubbing.
Re: Rocker arm geometry on a 440 [Re: moparguy] #1414015
04/02/13 11:44 PM
04/02/13 11:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Add me to the shim up the shaft crowd.
How do those springs fit on those retainers , the retainers look a little small ??
Re: Rocker arm geometry on a 440 [Re: rickraw] #1414016
04/03/13 12:41 AM
04/03/13 12:41 AM
gregsdart Offline
gregsdart  Offline
I don't agree with that. The rocker shaft bolt is not parallel with the intake valve, it is inclined towards it. The higher you move the rocker shaft, the closer the rocker and valve tip get, and the further out the scrub pattern will be, given you are going in the right direction to get the proper rocker arm to valve angle.
The first thing to do is to figure out at what angle the rocker is to the valve stem right now.
Re: Rocker arm geometry on a 440 [Re: rickraw] #1414017
04/03/13 01:18 AM
04/03/13 01:18 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Ya. the shaft shimming doesn`t work here but lash caps may help and also spread the load.............that`s what I`ve done 4 years.
Re: Rocker arm geometry on a 440 [Re: Thumperdart] #1414018
04/03/13 06:05 AM
04/03/13 06:05 AM
Australia
big_wedge Offline
big_wedge  Offline
Australia
those retainers look way to small for those springs... jus sayin
Re: Rocker arm geometry on a 440 [Re: gregsdart] #1414019
04/03/13 11:00 AM
04/03/13 11:00 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I never looked at the hold down bolt to valve angle relationship, if this is the case then shimming the shaft up would move the shaft towards the valve.
Lash caps would be the easier way to do do it , the OP will need to change his valve locks because those are the kind that accept lash caps. Otherwise it's machining off, or machining of, the stands .
Re: Rocker arm geometry on a 440 [Re: JohnRR] #1414020
04/03/13 12:48 PM
04/03/13 12:48 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I'm not sure that shimming will make it worse,
take it to the extreme i.e. if you shimmed it an inch, the arc of the tip would be passing the valve on the inside, or is my reasoning wrong??
Joe
Re: Rocker arm geometry on a 440 [Re: jlatessa] #1414021
04/03/13 01:06 PM
04/03/13 01:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Joe
that was my thought , but that was ASSuMEing the rocker shaft holdown pedestals were parallel to the valve stems , they angle toward the valves it seems, I don't have a head handy to confirm this.
Re: Rocker arm geometry on a 440 [Re: JohnRR] #1414022
04/03/13 01:17 PM
04/03/13 01:17 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I think what some are missing is that the tip of the rocker travels in an arc and the contact point has to move because of that...Hmmm
I have a head in the basement, I'll see if I can see some change.
Joe
Re: Rocker arm geometry on a 440 [Re: jlatessa] #1414023
04/03/13 01:33 PM
04/03/13 01:33 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
With the stamped rockers I have,
the contact point is not easily seen.
Joe
Re: Rocker arm geometry on a 440 [Re: jlatessa] #1414024
04/03/13 01:44 PM
04/03/13 01:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'll be interesting to see what the fix is , I have sharps going on 906's when I get my block back .
Re: Rocker arm geometry on a 440 [Re: JohnRR] #1414025
04/03/13 01:52 PM
04/03/13 01:52 PM
Gilbert AZ
tsanchez Offline
tsanchez  Offline
Gilbert AZ
The fulcrum point needs to be lowered to fix the geometry, by milling or removing shims if there is some. Raising will make it worse.
Re: Rocker arm geometry on a 440 [Re: moparguy] #1414026
04/03/13 03:48 PM
04/03/13 03:48 PM
AndyF Online content
AndyF  Online Content
To make it perfect you need longer valves or you need to lower the rocker shaft. Neither of those fixes is very simple. Lash caps will help but they add another part to the mix and you will most likely need to change pushrods.
Setting up a BB Mopar to have "perfect" valvetrain geometry is no picnic.
Flip thru the valvetrain chapter in my big block book. I show a bunch of examples and some fixes.
The best fix is to buy rocker arms which are the correct length for the application. Some rocker arms are really short, others are too long.
Page 1 of 3 1 2 3
