Power to Manual steering conversion #1413981
04/02/13 10:17 PM
04/02/13 10:17 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I have a 68 Dart that currently has power steering. But I would like to convert it to manual steering. Will a steering shaft from a manual steer 68 Valiant work with my power steering column and a manual steer box??? Do I need anything else for the swap? I already have a manual steer coupler.
Re: Power to Manual steering conversion [Re: mopowers] #1413982
04/02/13 11:20 PM
04/02/13 11:20 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
The column shaft is longer on the man. They sell an add on extension. Mancini has it. It is no big deal. Maybe you'll want to try one of Flamming Rivers 16-1 ratio. It's pricy, but I liked it. Not as good as a rack though, I loved those.
Re: Power to Manual steering conversion [Re: mopowers] #1413983
04/03/13 12:23 AM
04/03/13 12:23 AM
Tri-Cities, Washington
V
VITC_GTX Offline
VITC_GTX  Offline
V
I swapped my '69 Barracuda from power steering to manual steering. Replaced the gearbox and swapped just the column steering shaft in my column for a column steering shaft out of a '71 Demon column that had manual steering. Everything worked great. You should be good to go.
Re: Power to Manual steering conversion [Re: VITC_GTX] #1413984
04/03/13 10:31 AM
04/03/13 10:31 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks you guys!
Re: Power to Manual steering conversion [Re: mopowers] #1413985
04/03/13 12:49 PM
04/03/13 12:49 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Make sure the nylon shear pins are in tact if you decide to just swap out the inner shaft. They allow the shaft to collapse in the event of blunt force to your chest.
BTW, I believe the manual column is 3" longer.
Re: Power to Manual steering conversion [Re: Pntastar69] #1413986
04/03/13 01:02 PM
04/03/13 01:02 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Where are the nylon shear pins located? I've never had one of these apart before.
Re: Power to Manual steering conversion [Re: mopowers] #1413987
04/03/13 01:36 PM
04/03/13 01:36 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
all you need is the man box and a steering adaptor. Mancini sells them. You can try e-bay for a used one, they 'aint cheap, like $130
Coming soon!!!!
Re: Power to Manual steering conversion [Re: mopowers] #1413988
04/03/13 01:38 PM
04/03/13 01:38 PM
P
Pntastar69 Offline
Pntastar69  Offline
P
The inner shaft is collapsable in the event of an accident, steering wheel into chest. The sheer pins are in the middle of the inner shaft.
Re: Power to Manual steering conversion [Re: mopowers] #1413989
04/03/13 01:44 PM
04/03/13 01:44 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
much easier than swaping the actual column. http://chucker54.stores.yahoo.net/mamastad.html
Re: Power to Manual steering conversion [Re: Mr.Yuck] #1413990
04/03/13 03:05 PM
04/03/13 03:05 PM
P
Pntastar69 Offline
Pntastar69  Offline
P
Yes, easier, but more $$. I picked up a junk column for $15 and just used the inner shaft. Just throwin out some options for the OP.
Re: Power to Manual steering conversion [Re: Pntastar69] #1413991
04/03/13 03:21 PM
04/03/13 03:21 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
What was the junk column out of??
I know there adapters out there. I'd rather not use one though, if I can just get the proper length shaft.
Re: Power to Manual steering conversion [Re: Pntastar69] #1413992
04/03/13 03:22 PM
04/03/13 03:22 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
What happens if the shear nylon pins are not in tact? Can I replace them with something?
Re: Power to Manual steering conversion [Re: mopowers] #1413993
04/03/13 05:46 PM
04/03/13 05:46 PM
P
Pntastar69 Offline
Pntastar69  Offline
P
Got a column from a 67 Dart
Shear pin info
http://www.dodgecharger.com/forum/index.php?topic=5404.0
Re: Power to Manual steering conversion [Re: Pntastar69] #1413994
04/03/13 07:10 PM
04/03/13 07:10 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I changed my 63 from power to manual steering. Just used the manual box and added the steering adapter you can see here. The same one Mr Yuck posted. Ron
Re: Power to Manual steering conversion [Re: mopowers] #1413995
04/03/13 07:26 PM
04/03/13 07:26 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
I had a problem with the Firm Feel adapter (shown) fitting the box loosely.
So, yet another option, since you have the manual coupler, would be to cut the shaft and add 2.5" of .75" round stock to the PS shaft. I used a simple jig to hold everything in alignment for welding. A coupler rebuild kit can be ordered at your local parts store cheaper than what they're selling for online: Dorman "Steering shaft rebuild kit" # 425-253
Re: Power to Manual steering conversion [Re: 70Duster440] #1413996
04/03/13 07:32 PM
04/03/13 07:32 PM
kalispell montana
jwilson 61 Offline
jwilson 61  Offline
kalispell montana
Another option is weld the factory manual coupler to the bottom of the power steering coupler it works perfect as I've done it several times. perfect length difference.
70 cuda 440 6bbl Auto with a dana 60
68 road runner QQ1 383 auto
1970 6 barrel 4 speed Superbird FY1 number matching
15 Challenger 6.4 SRT pearl White 6 Speed
72 Cuda 440 5 speed
71 Road Runner 440 4 speed
Re: Power to Manual steering conversion [Re: 383man] #1413997
04/22/13 12:24 PM
04/22/13 12:24 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Hey Ron,
Did you cut your tube down? What did you use for a lower support bearing?
Thanks!
Re: Power to Manual steering conversion [Re: mopowers] #1413998
04/22/13 07:12 PM
04/22/13 07:12 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I did the same as Ron for my steering. I wonder if anyone has used one of the available universal joint setups to replace the coupler and if so, how's it working out for you?
Re: Power to Manual steering conversion [Re: rbstroker] #1413999
04/22/13 07:56 PM
04/22/13 07:56 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Here is how to lengthen the shaft without buying a bunch of stuff: the inner shaft and the outer shaft will telescope in the event of a crash. The thing that prevents them from moving under normal circumstances is a nylon "pin" in a hole that goes crossways thru the shaft in the area where the inner and outer shafts overlap. The nylon pin looks like it is cast in place somehow.
What you can do is whack the bottom end of the shaft with a BFH to shear off the nylon pin. Then you can pull the lower shaft down untill it is the right length for the manual box. Another set of holes should then be in alignment that you can put a soft aluminum or nylon pin back into. If they are not in alignment, you can drill a new hole.
Worked for me. Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Power to Manual steering conversion [Re: Hemi_Joel] #1414000
04/22/13 09:04 PM
04/22/13 09:04 PM
Oakdale, MN
W
weazel Offline
weazel  Offline
W
Oakdale, MN
I have a 67 manual floor shift steering column that has been rebuilt/repainted that will bolt in. The only issue is that it does not have the key on the column. Since 67 barracudas had the ignition on the dash. Im not sure where your ignition switch is? If interested shoot me a pm.
