horsepower estimate #1413686
04/02/13 02:56 PM
04/02/13 02:56 PM
wv
Dartcuda Offline OP
Dartcuda  Offline OP
wv
Best guess this combo. Early 360 block with Scat 4" stroker kit at 10.5 to 1 compression . Comp Cams hydraulic flat tappet XE-295HL , 251-257 @.050" W/Harland Sharp 1.5 rockers. SDSS stage 2 Edelbrocks , flow 285 @ .500" Ported air gap , holley 950 HP and TTI 1-5/8"-1-3?4 step headers.
Re: horsepower estimate [Re: Dartcuda] #1413687
04/02/13 05:44 PM
04/02/13 05:44 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I'd say 475 horsepower.
Re: horsepower estimate [Re: Dartcuda] #1413688
04/02/13 05:49 PM
04/02/13 05:49 PM
Renton Washington
Triple Threat Offline
Renton Washington
https://board.moparts.org/ubbthreads/show...rt=all&vc=1
Your heads are a bit better than the RHS's. Should run strong.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: horsepower estimate [Re: Dartcuda] #1413689
04/02/13 06:37 PM
04/02/13 06:37 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Ryan's stage 2 don't flow 285@500
This is copied from his website for stage 4 and a 2.05 valve.
EDELBROCK STAGE 4 PORT WORK
LIFT------IN/EX
.100"----76.0/N/A
.200"--147.0/112.1
.300"--206.7/163.9
.400"--255.3/193.2
.450"--274.3/203.6
.500"--279.0/212.2
.550"--285.0/218.0
.600"--293.2/226.3
.650"--293.2/229.4
.700"--293.2/230.8
All #'s at 28" of H20.
Ported head was flowed with 2.05" FERREA valve with 30 degree back cut on intake valve, and no flow tube on exhaust.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: horsepower estimate [Re: Dartcuda] #1413690
04/02/13 06:39 PM
04/02/13 06:39 PM
Washington
skrews Offline
skrews  Offline
Washington
520ish
Re: horsepower estimate [Re: skrews] #1413691
04/02/13 10:12 PM
04/02/13 10:12 PM
wv
Dartcuda Offline OP
Dartcuda  Offline OP
wv
Sorry , had to dig out Ryans stage 2 flow chart. so 285 @ .550
.100--71.2
.200--143.8/107.1
.300--198.3/148.7
.400--242.0/189.6
.450--254.1/203.1
.500--272.5/208.6
.550--284.7/211.3
.600--287.8/214.7
Re: horsepower estimate [Re: Dartcuda] #1413692
04/02/13 10:17 PM
04/02/13 10:17 PM
wv
Dartcuda Offline OP
Dartcuda  Offline OP
wv
I was hoping for 500
