How can I tell what Transmission I have? #141348
10/25/08 03:46 PM
10/25/08 03:46 PM
Anonymous OP
Anonymous OP
I found out my current truck has had a few transmission in it since it was bought. I thought it had a 727 until today. Is there some way I can get under the truck and see what kind it is?
Re: How can I tell what Transmission I have? #141349
10/25/08 03:49 PM
10/25/08 03:49 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
A 727 has a big hump out the side of the pan at the dipstick, a 904 is square there. What year truck?
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: How can I tell what Transmission I have? [Re: 70dart360] #141350
10/25/08 03:54 PM
10/25/08 03:54 PM
Anonymous OP
Anonymous OP
1986
Re: How can I tell what Transmission I have? #141351
10/25/08 03:57 PM
10/25/08 03:57 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Might be a lock up converter trans then. The gaskets are the same, there should be a single wire plug on the front drivers side where the lines are if it is. What are you trying to do with it?
Re: How can I tell what Transmission I have? [Re: 70dart360] #141352
10/25/08 05:47 PM
10/25/08 05:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
