How can I tell what Transmission I have?
#141348
10/25/08 03:46 PM
10/25/08 03:46 PM
I found out my current truck has had a few transmission in it since it was bought. I thought it had a 727 until today. Is there some way I can get under the truck and see what kind it is?
Re: How can I tell what Transmission I have?
#141349
10/25/08 03:49 PM
10/25/08 03:49 PM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
A 727 has a big hump out the side of the pan at the dipstick, a 904 is square there. What year truck?
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
[Re: 70dart360]
#141350
10/25/08 03:54 PM
10/25/08 03:54 PM
1986
#141351
10/25/08 03:57 PM
10/25/08 03:57 PM
70dart360
Green Meister
Green Meister
Hampton, Ga.
Might be a lock up converter trans then. The gaskets are the same, there should be a single wire plug on the front drivers side where the lines are if it is. What are you trying to do with it?
70 Dart Swinger
