Re: launch RPM's
[Re: Quicktree]
#1413004
04/01/13 05:14 PM
04/01/13 05:14 PM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The lowest I can make em hook and be consistent is best in my opinion. When I moved weight forward to settle wheel stands, I had to raise the launch rpm to hit the tires harder and stick them. Still, I am well below full throttle.
Re: launch RPM's
[Re: Quicktree]
#1413005
04/01/13 05:39 PM
04/01/13 05:39 PM
Posts: 7,506 Az
Crizila
Az
Makes a big difference in RT, especially if you are well below convertor flash. ----- Don't ask me how I know .
Fastest 300
Re: launch RPM's
[Re: Crizila]
#1413006
04/01/13 05:45 PM
04/01/13 05:45 PM
Quicktree
not in a light car
Re: launch RPM's
[Re: Crizila]
#1413011
04/02/13 05:43 PM
04/02/13 05:43 PM
Posts: 3,421 Toronto
mshred
Toronto
Leaving at a lower rpm slows down the r/t's?
Re: launch RPM's
[Re: Triple Threat]
#1413013
04/02/13 06:34 PM
04/02/13 06:34 PM
mshred
Toronto
Yes
I guess that makes sense since you would be leaving with less inertia, or in the case of a converter car there is that time it takes for the converter to flash up to the stall rpm?
Re: launch RPM's
[Re: mshred]
#1413014
04/02/13 06:39 PM
04/02/13 06:39 PM
Quicktree
Yes
it would be more pronounced the heavier the car is. have driven heavy cars now in a super light one the difference is huge. my 60' was exactly the same and i seen little change in rt
Re: launch RPM's
[Re: Quicktree]
#1413015
04/02/13 07:00 PM
04/02/13 07:00 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
My car is a heavy street B-Body. I have found that lowering Launch RPM's slows BOTH my RT and 60'. I think this is unique to the combo, though.
Re: launch RPM's
[Re: StealthWedge67]
#1413016
04/02/13 07:16 PM
04/02/13 07:16 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I have left from an idle up to coming up on the converter to 2500. I like it best coming up on the converter to about 2000 as my heavy B-body seems to like that about the best with my 9.5 Dynamic converter. Ron
Re: launch RPM's
[Re: Crizila]
#1413020
04/02/13 11:17 PM
04/02/13 11:17 PM
StealthWedge67
Puyallup, WA
Based on those slips and your launch RPM info, you're in the same boat with most of us: RT and 60' slowed dramatically with the lower RPM.
