Rear sway bars, fact or myth?
#1412475
03/31/13 10:18 PM
03/31/13 10:18 PM
Posts: 22,731 Bitopia
jcc
Bitopia
New Improved- Does a rear sway bar ALWAYS improve the handling of a car? OLD (Does EVERY car require a rear swaybar to handle better?) YES or NO? What say you? Define "handle" in your own way if needed. I have an opinion. Majority doesn't necessarily win http://www.stealthtdi.com/SwayBars.html A reasonable middle of the road pun intended swaybar discussion
Re: Rear sway bars, fact or myth?
[Re: amxautox]
#1412477
03/31/13 10:25 PM
03/31/13 10:25 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
'handle properly' 'predictable'
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: jcc]
#1412478
03/31/13 10:30 PM
03/31/13 10:30 PM
Posts: 39 Beeton Ontario. Canada
BigSugar
YES or NO?
I have an opinion.
Why not just bolt one on and see for yourself ?
If you don't think it's an improvement you can always take it off.
Ron
[Re: jcc]
#1412480
03/31/13 10:54 PM
03/31/13 10:54 PM
Posts: 27,480 So Cal
autoxcuda
So Cal
YES or NO?
I have an opinion.
No
No
Never absolutes on something like that. But they are an easy tool to make under/over-steer balance adjustments depending on the situation and driver preference.
It all depends on the rest of the handling system you are considering adding a rear sway bar to.
[Re: autoxcuda]
#1412481
04/01/13 10:30 AM
04/01/13 10:30 AM
Posts: 416 Franklin Co. Illinois
runinonmt
I'm no suspension expert by any means but real world example: After noticing the improvement on my truck we bought a rear swaybar for my Stepson's '88 Ranger x cab. When he bought a new Ram QC in '03 the rear swaybar was the first improvement he made. He drives to Ft. Worth daily and he said the improvement on the onramps was impressive. Ron
In sixty-five I was seventeen and running up one-o-one
I don't know where I'm running now, I'm just running on
Jackson Browne-Running On Empty
[Re: Kern Dog]
#1412483
04/01/13 04:33 PM
04/01/13 04:33 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
I know that my 70 Charger is more fun to drive with the current setup, which includes a rear bar. I don't like understeer. I don't like excessive body roll either. The bar made huge reductions in both.
Absolutely...
Got a rear sway on my '71 Satellite...
Big difference...
[Re: 5spdcuda]
#1412484
04/01/13 05:11 PM
04/01/13 05:11 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
Personally I try not to use a rear bar on rear drive cars. An anti-roll bar always trys to lift the inside wheel. This can make trying to get the power down on corner exit pretty tricky especially if you have good power or marginal grip. As for defining "good handling" I see it as having good balance, sharp turn in and a good general feeling of confidence that it won't do anything weird.. Predictability is certainly desirable, but if the balance is really off it dosen't help your confidence just because you know ahead of time that the car is going to either try to suddenly swap ends or push itself off the outside of the corner.
Isn't omitting a rear bar on a RWD car really only of benefit on autocross where you have high grip + very tight turns? In any other situation I think you would want the roll stiffness.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: 72Swinger]
#1412486
04/01/13 06:02 PM
04/01/13 06:02 PM
Secret Chimp
Eugene, Oregon
Usually in an Autox scenario a rear bar is a help. In theory in would make the car rotate in the tight turns of a tight turned course. I installed a rear bar on my Dart toward the end of last summer and it made a difference for sure. I can induce oversteer pretty easy with the throttle. And on long sweepers the car is definitely more confident and flat. One down side to it on my car is on turns where the pavement is broken up with cracks,seams or small potholes the rear is alot less compliant and wants kick sideways a little.
I only know that the only situation where Miata owners omit the rear bar entirely is for autox because it helps keep the inside tire on the ground in extremely tight turns that transition to hard acceleration. Otherwise you want a rear bar to keep the car balanced at higher speeds. It is possible to have too much rear bar and get the wheel lifting at something more than a full-lock turn at 20 mph, but I don't think the answer is no rear bar at all.
[Re: Secret Chimp]
#1412488
04/01/13 09:36 PM
04/01/13 09:36 PM
autoxcuda
So Cal
Are those Miata's in stock classes that have to run stock springs and stock width tires?
It all depends on the individual car and it's spring/shock/swaybar/tire setup. All results will very.
[Re: jcc]
#1412490
04/01/13 09:51 PM
04/01/13 09:51 PM
Secret Chimp
Eugene, Oregon
Specific setups aside, I can't bear to see people arguing that rear bars should not be necessary as a general rule. Come on, guys. Our cars may be 40-50 years old but the general suspension theory we're working doesn't have to be...
[Re: Secret Chimp]
#1412491
04/01/13 10:54 PM
04/01/13 10:54 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
It really depends.
Best handling car I ever built was vastly improved with a rear bar. But unless you have major buxs you can't always get the exact setup you need, so you tune with what you can get.
If you like stiff springs, then you can get away with no, or a small, rear bar.
If you like to keep your dental work where it belongs you are probably running a rear bar.
[Re: Secret Chimp]
#1412494
04/02/13 09:40 AM
04/02/13 09:40 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
generally adding roll stiffness to the front promotes understeer, adding roll stiffness to the rear promotes oversteer. on my old M body, when I upgraded the front to the cop spec 1.125" bar, and hadn't put on the rear bar, the thing pushed like a plow, it just wouldn't turn. I actually went to a 1" rear bar, and it made it very responsive, possibly almost slightly biased towards oversteer. also, wider tires on the back relative to the front helps induce understeer, so you may need more rear bar if you run a staggered tire setup.
the big difference between miatas and mopars is the miata is IRS, while the mopar is a live axle. adding roll bars on an independent suspension makes them a little less independent, so how a miata reacts to a rear sway bar is somewhat different than how a live axle vehicle will...
