How to move a 70 Charger with locked steering column... #141228
10/25/08 08:56 AM
10/25/08 08:56 AM
Wichita,KS
Blakcharger440 Offline OP
Wichita,KS
I need to move a 70 charger I just brought into the garage. The problem is that the steering column is locked and I dont have a key.....I need to make several turns to get it into the garage!
How can I get the steering column unlocked or get the wheels to turn???
There is probably an obvious answer to this problem that I am overlooking.
Re: How to move a 70 Charger with locked steering column... [Re: Blakcharger440] #141229
10/25/08 09:21 AM
10/25/08 09:21 AM
NH
72challorange Offline
He's Game
He's Game
NH
Use a set of wheel dollies for now or a good sized floor jack.
Tom
Re: How to move a 70 Charger with locked steering column... [Re: Blakcharger440] #141230
10/25/08 09:23 AM
10/25/08 09:23 AM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
You could replace the ignition switch or, get a set of wheel dollys, then roll the car where ever you like.
Re: How to move a 70 Charger with locked steering column... [Re: repad] #141231
10/25/08 09:31 AM
10/25/08 09:31 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
replacing the ing switch is a PITA. I'd vote for dollies. I have a spare column w/ key if you are intrested. It needs all new wires but it's black and in decent shape.
Re: How to move a 70 Charger with locked steering column... [Re: Mr.Yuck] #141232
10/25/08 09:54 AM
10/25/08 09:54 AM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
I move them around with a floor jack all the time, just jack it up and pull the jack to either side and push.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: How to move a 70 Charger with locked steering column... [Re: 70dart360] #141233
10/25/08 09:59 AM
10/25/08 09:59 AM
Gateway to the West.
hemi_harvester Offline
IT you don't care about the column you can jerk the steering wheel hard and it will turn past the lock it works put it will wear YOU out doing it. Some are more loose than others.
OR take the column out and careful put vise grips on the steering box
OR unbolt the tie rod ends and you can KICK the wheels any way you want..
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: How to move a 70 Charger with locked steering column... [Re: Blakcharger440] #141234
10/25/08 12:17 PM
10/25/08 12:17 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
The 2 easiest ways are to just knock the roll pin out of the steering coupler, remove 3 bolts and 2 nuts and take the steering column completely out. Then turn the wheels by hand. The other way is to take the passenger side door lock out, and take it to a locksmith and get a key made.
Re: How to move a 70 Charger with locked steering column... [Re: JDMopar] #141235
10/25/08 01:26 PM
10/25/08 01:26 PM
Harrisburg, Pa.
screamindriver Online content
screamindriver  Online Content
Harrisburg, Pa.
Is it a floor shift car ??? If so the the 70 has the steering colum lock rod you could just disconnect and spin to disengauge the steering column lock.....No key needed to just steer it around...
Re: How to move a 70 Charger with locked steering column... [Re: JDMopar] #141236
10/25/08 04:18 PM
10/25/08 04:18 PM
Wichita,KS
Wichita,KS
The car is on a rock driveway so I could not use a dolly....I should have mentioned that. I ended up disconnecting the steering column from the box and turned the wheels by hand since there is no engine or trans and it was easy to do. Thanks guys!
