IDLER ARM QUESTION................ #1412087
03/31/13 12:21 PM
03/31/13 12:21 PM
State of confusion
Thumperdart Offline OP
State of confusion
I just replaced the worn out idler arm and was curious if there`s a torque spec or how tight the bolt should be cranked to. Does the bolt act as the fulcrum or does the sleeve actually rotate within the arm..........thankxxx, not a ft. end guy.
Re: IDLER ARM QUESTION................ [Re: Thumperdart] #1412088
03/31/13 12:49 PM
03/31/13 12:49 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Us the standard torque for that size and thread pitch, the bushing is fixed and the idler rotates around it. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: IDLER ARM QUESTION................ [Re: Thumperdart] #1412089
03/31/13 12:51 PM
03/31/13 12:51 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
40# torque. it's a taper fit in the link. it just pivots in it's socket.
Re: IDLER ARM QUESTION................ [Re: astjp2] #1412090
03/31/13 12:54 PM
03/31/13 12:54 PM
State of confusion
State of confusion
I just tightened it snug but as I tightened it more I noticed it would bind up hense the reason for asking. So the sleeve is fixed to the idler arm and the bolt takes the load? Thankxxx..........
Re: IDLER ARM QUESTION................ [Re: rickraw] #1412091
03/31/13 01:37 PM
03/31/13 01:37 PM
State of confusion
State of confusion
So, r u saying the sleeve spins INSIDE of the idler arm or around the bolt...........
Re: IDLER ARM QUESTION................ [Re: Thumperdart] #1412092
03/31/13 02:23 PM
03/31/13 02:23 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
my mistake. the mounting end has the sleeve that spins in the arm. torque on that bolt is 65#. mine did the same thing as ur's. what is happening is the mounting tabs are crushing against the arm. i made 2 shims to fit between the mounting tab & the sleeve in idler arm.
Re: IDLER ARM QUESTION................ [Re: rickraw] #1412093
03/31/13 02:38 PM
03/31/13 02:38 PM
State of confusion
State of confusion
The new arm came w/washers which called for one on the top and bottom of the sleeve but only could fit one washer on top which is how I did it before. So I guess I`ll tighten it up some and go from there but it doesn`t appear to be binding on the arm itself but I`ll double check.
Re: IDLER ARM QUESTION................ [Re: Thumperdart] #1412094
03/31/13 02:50 PM
03/31/13 02:50 PM
New York
DartS Offline
DartS  Offline
New York
I just replaced mine and the torque spec was 65 ft lbs.
Re: IDLER ARM QUESTION................ [Re: DartS] #1412095
03/31/13 03:07 PM
03/31/13 03:07 PM
State of confusion
State of confusion
So after you torqued it to spec did it still move freely?
Re: IDLER ARM QUESTION................ [Re: Thumperdart] #1412096
03/31/13 04:08 PM
03/31/13 04:08 PM
New York
DartS Offline
DartS  Offline
New York
It was tight. But when I put the rest of the steering back together it turned with no binding.
Re: IDLER ARM QUESTION................ [Re: DartS] #1412097
03/31/13 04:33 PM
03/31/13 04:33 PM
State of confusion
State of confusion
Thankxxxx.............makes sense on it being tight since I was turning just the arm w/one hand on my back.........
