Rusty 440 forged crankshaft - too rusty to use? #1411639
03/30/13 08:16 PM
03/30/13 08:16 PM
dusterguy Offline OP
I have a crankshaft that has sat in an unheated garage for the last 15 years. I am wondering if it will clean up with machine work or is it toast. Will it tear up the rear main seal? Please look at the picture and tell me if I have a new doorstop.
Re: Rusty 440 forged crankshaft - too rusty to use? [Re: dusterguy] #1411640
03/30/13 08:40 PM
03/30/13 08:40 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Most any crank that is straight and not cracked can be repaired, check with a machine shop. It might be best to acid dip it take care of any rust in the oil passages.
Re: Rusty 440 forged crankshaft - too rusty to use? [Re: dusterguy] #1411641
03/31/13 12:40 AM
03/31/13 12:40 AM
Cab_Burge Online work
Cab_Burge  Online Work
I would have it thoroughly cleaned, hot tank, glass bead blasted or media(plastic beads) blasted and go from there, I would think of using that one for a offset ground 3.91 stroke in a low deck
Re: Rusty 440 forged crankshaft - too rusty to use? [Re: Cab_Burge] #1411642
03/31/13 04:54 AM
03/31/13 04:54 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Just make sure to watch how all these extra costs are going to add up. Used GOOD 440 steel cranks are easy to find, and you shouldn't be out more than $150-200 for one that just needs polishing. Start spending $3-400 on the old one and you could be close to getting a stroker crank, or at least a new stock stroke crank.
Re: Rusty 440 forged crankshaft - too rusty to use? [Re: Pale_Roader] #1411643
03/31/13 11:04 AM
03/31/13 11:04 AM
Indy
moparman89 Offline
moparman89  Offline
Indy
Pass on that.
School of Automotive Machinists Racing
Re: Rusty 440 forged crankshaft - too rusty to use? [Re: dusterguy] #1411644
03/31/13 11:48 AM
03/31/13 11:48 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
What Pale Roader said. It's nice to save the old stuff but when you can buy new 4.15 stroke cranks for $400 like I did a few years ago it doesn't make sense to save this one for a 440 build. I would consider nipping it down for a B stroker build though as CAB said.
I'm sure if you had it to do over again you would have spread a big of grease on those journals.
Sheldon
Re: Rusty 440 forged crankshaft - too rusty to use? [Re: RUNCHARGER] #1411645
03/31/13 12:48 PM
03/31/13 12:48 PM
I got it in a parts deal this way. I just didn't want to throw it away because I virtually have nothing invested in it. I will take it to my machine shop and see what it looks like after a dip and blast. Wish me luck!
Re: Rusty 440 forged crankshaft - too rusty to use? [Re: dusterguy] #1411646
03/31/13 02:36 PM
03/31/13 02:36 PM
iowa
rook440 Offline
rook440  Offline
iowa
there is a simple way to clean the rust off at home...check out electrolosis online...I discovered this truely unreal cheap process when i was working on my mill..all u need is a
10 dollar tote a battery charger some rerod and a box of borax laundry booster..ive used on crankshafts anyone would have thrown away and they came perfectly clean...youtube might have a video on this but it is definately the wat to go for rust removal from anything..
Re: Rusty 440 forged crankshaft - too rusty to use? [Re: rook440] #1411647
03/31/13 09:49 PM
03/31/13 09:49 PM
SW FL
dodgedartgt Offline
dodgedartgt  Offline
SW FL
Rook440
Can you post any before / after pictures? I'm aware of the electrolysis process, and would like to see more/
Thnx, Mike in FL
