what happend? #1411596
03/30/13 07:20 PM
03/30/13 07:20 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
i took apart a 496 rb it has mabey 20 passes but got some water in it.all i did was cross hatch it and rering it,the berings look good and the journals all look real good.heres the delema.when i put one rod on there isnt enough room for the other one.i even took 2 end caps and went down the line and they dont fit on any journal.yes i numbered everthing to go back together.
Re: what happend? [Re: bonefish] #1411597
03/30/13 07:32 PM
03/30/13 07:32 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I am not sure I understand what you are saying. You mean two rods won't fit on one journal ?
Re: what happend? [Re: VernMotor] #1411598
03/30/13 07:38 PM
03/30/13 07:38 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
exactly
Re: what happend? [Re: bonefish] #1411599
03/30/13 07:41 PM
03/30/13 07:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm thinkin you have the rod turned backwards and the
camfer on the bearing is hitting the crank radius
EDIT
if the rod is right then you put the bearing in wrong..
you put the top in the bottom and visa versa
Re: what happend? [Re: MR_P_BODY] #1411600
03/30/13 07:49 PM
03/30/13 07:49 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
EDIT
DADGUMMITT,thats exactly what i did. :igot the rod together right its just bakkerds.thanks
Re: what happend? [Re: bonefish] #1411601
03/30/13 07:53 PM
03/30/13 07:53 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
I knew it had to be something silly if everything fit before you took it apart.
Re: what happend? [Re: bonefish] #1411602
03/30/13 07:58 PM
03/30/13 07:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
At least you found it... minor issue
Re: what happend? [Re: MR_P_BODY] #1411603
03/30/13 08:31 PM
03/30/13 08:31 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
Yeh, but there for a while i though i was in the TWYLIGHT ZONE.
Re: what happend? [Re: bonefish] #1411604
03/30/13 09:00 PM
03/30/13 09:00 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Don't feel too bad, on my last 440 build, I had 4 of the rods backwards, those little spirolocks were a pain to take apart again.
Re: what happend? [Re: cgall] #1411605
03/30/13 09:10 PM
03/30/13 09:10 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
YEH,i dont do enough of this to remember everything,thank goodness for the guys on this board who are willing to help.
Re: what happend? [Re: bonefish] #1411606
03/31/13 07:58 PM
03/31/13 07:58 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
What a BONEFISH
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: what happend? [Re: bonefish] #1411607
03/31/13 08:40 PM
03/31/13 08:40 PM
Most stock Mopar rod bearings don't need to be in the upper or lower positions only, not so on the BB Chevy and most of the race rod bearings Murphy got you
Re: what happend? [Re: hemi-itis] #1411608
03/31/13 11:25 PM
03/31/13 11:25 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
What a BONEFISH
HEY!!! i resemble that remark.
