273 cam #1411040
03/29/13 10:50 PM
03/29/13 10:50 PM
Ontario. Canada
hemidere Offline OP
hemidere  Offline OP
Ontario. Canada
My chum has a 66 Barracuda with a 273. He wants to swap the factory solid cam for a mild hydraulic. Any issues?
Re: 273 cam [Re: hemidere] #1411041
03/29/13 10:54 PM
03/29/13 10:54 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
273's were all solid lifter motors. If he wants to do a small hydraulic swap he will need push rods and a set of hydraulic rockers from a 318. I used a 284-484 Mopar Performance cam in one and it ran pretty good.
...FAFO...
Re: 273 cam [Re: hemidere] #1411042
03/29/13 11:10 PM
03/29/13 11:10 PM
May I ask what issue is he haveing with the solid cam?
Re: 273 cam [Re: RapidRobert] #1411043
03/29/13 11:37 PM
03/29/13 11:37 PM
Ontario. Canada
hemidere Offline OP
hemidere  Offline OP
Ontario. Canada
No issue, he wants a little more performance.
Re: 273 cam [Re: skicker] #1411044
03/30/13 12:11 AM
03/30/13 12:11 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Not the 68 and 69 273s, they were all hydraulic. You can run the adjustable rockers, but the stock pushrods won't be the correct length. The easy thing to do is swap to the non-adjustable rockers and corresponding pushrods.
Re: 273 cam [Re: hemidere] #1411045
03/30/13 12:11 AM
03/30/13 12:11 AM
IN
ahy Offline
ahy  Offline
IN
If performance is the objective, a solid will generally be better. The solid can get the valves open a little faster and farther for any given duration. That means more performance with less trade-off in drivability and economy. How about a bigger solid with matching spings?
Re: 273 cam [Re: ahy] #1411046
03/30/13 12:25 AM
03/30/13 12:25 AM
Ontario. Canada
hemidere Offline OP
hemidere  Offline OP
Ontario. Canada
He has a NOS 340 hyd cam a parts guy found while doing a clean out at one of the local Dodge dealers, left over from the 70's. If he can swap with the solid is what we need to know...
Re: 273 cam [Re: hemidere] #1411047
03/30/13 12:38 AM
03/30/13 12:38 AM
As said need rockers/pushrods. I have some extras you can have for the shipping (I think I have 16 pushrods) & shafts too. That way you can keep the solid rocker/shaft assys together to keep or sell
Re: 273 cam [Re: hemidere] #1411048
03/30/13 07:35 AM
03/30/13 07:35 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Dropping in a 318 would be easier.
Re: 273 cam [Re: jcc] #1411049
03/30/13 10:01 AM
03/30/13 10:01 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
a motor swap is easier than a cam swap?
Re: 273 cam [Re: 65rbdodge] #1411050
03/30/13 10:12 AM
03/30/13 10:12 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
You're going to have to change pushrods, but you can keep the cast adjustable rocker arms. Smith Brothers can fix you up with pushrods or you can get them ready-made from Summit or Jeg's.
This is the land of the free because of the brave
Re: 273 cam [Re: 65rbdodge] #1411051
03/30/13 10:13 AM
03/30/13 10:13 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It is if it isn't you doing it.
To the OP, all you really need to swap in a hydraulic cam is the cam, the hydraulic lifters and a set of new push rods for hydraulic cam to adjustable rockers.
Don't be the exception.
Re: 273 cam [Re: Supercuda] #1411052
03/30/13 10:37 AM
03/30/13 10:37 AM
The stock 273 cam is super mild, even the 4-barrel cam only had 248 degrees duration. If it's an otherwise stock 273, the factory 340 cam is plenty big and will be a big improvement in performance.
You friend can either swap in 318/340/360 pushrods and non-adjustable rocker arms, or keep his adjustable rockers and just buy some pushrods ready-made for a hydraulic cam and adjustable rockers (which would be my choice).
Other than the pushrod issue, putting a hydraulic cam in an early 273 is no more or less complicated than changing cams in anything else.
Re: 273 cam [Re: hemidere] #1411053
03/30/13 02:56 PM
03/30/13 02:56 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Mancini brand for hydralic cams and adjustable rockers
http://chucker54.stores.yahoo.net/enhypusech.html
comp cams ones that should work
http://www.summitracing.com/parts/cca-7821-16/overview/
Re: 273 cam [Re: 65rbdodge] #1411054
03/30/13 04:14 PM
03/30/13 04:14 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Well based on the replies so far, 45 cubes is hard to overcome with a simple cam swap.
Re: 273 cam [Re: RapidRobert] #1411055
03/30/13 07:46 PM
03/30/13 07:46 PM
Ontario. Canada
hemidere Offline OP
hemidere  Offline OP
Ontario. Canada
Thanks Rapid Robert, I'll see him tonight and advise...Ian
Re: 273 cam [Re: hemidere] #1411056
03/30/13 09:32 PM
03/30/13 09:32 PM
Bismarck, ND USA
cageman Offline
cageman  Offline
Bismarck, ND USA
I'll put my 273 up against any 318. No way I would ever put a 318 in.
Re: 273 cam [Re: jcc] #1411057
03/31/13 01:17 AM
03/31/13 01:17 AM
scratchnfotraction Offline
I used a 273 hipo solid cam with .500 lift,that thing rocked.
I have used the 273 hipo solid in a few 318s,all 273 valve gear.
if you are going hydro cam/lifters stick a 318 whiplash cam in it.
Re: 273 cam [Re: scratchnfotraction] #1411058
03/31/13 01:34 AM
03/31/13 01:34 AM
Ontario. Canada
hemidere Offline OP
hemidere  Offline OP
Ontario. Canada
Thanks all, met with Darcey tonight. He's goin with the 340 hyd cam, 273 rockers & new pushrods. Should motivate the little Cuda nicely...
