Extraction tool for electrical connector? #1410889
03/29/13 05:38 PM
03/29/13 05:38 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
I need to remove some wires that attach to the fire-wall connector in a 69 GTX. The wires connect to the aft side of the connector (from the under dash wire harness) There is a special tool for this; an extraction tool. Does anyone know the correct extraction tool for this application? And where I can get one? Thanks
Re: Extraction tool for electrical connector? [Re: frank] #1410890
03/29/13 06:07 PM
03/29/13 06:07 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
I replaced the bulkhead in my 68 GTX back in the mid 80's with out a special tool. Its been too long ago, ...but I think I used a very, very small flat screw driver from the engine side of the bulkhead connector to release the little finger that holds them in once they're pushed in.
Re: Extraction tool for electrical connector? [Re: frank] #1410891
03/29/13 06:51 PM
03/29/13 06:51 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
As said, put a small screwdriver or thin set of pliers in from the engine side, squeeze the finger and pull the cable at the same time and it will come straight out. When you refit, just pull the finger on the spade out a little and it will lock in when pushed home.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Extraction tool for electrical connector? [Re: deaks] #1410892
03/29/13 08:22 PM
03/29/13 08:22 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
A small pick will work. Then before inserting the connector back make sure the little tang is raised so it will catch and lock.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: Extraction tool for electrical connector? [Re: frank] #1410893
03/29/13 09:44 PM
03/29/13 09:44 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Copy all. I will attempt extraction.
Re: Extraction tool for electrical connector? [Re: frank] #1410894
03/29/13 09:54 PM
03/29/13 09:54 PM
mini eyeglass screwdriver for the female ones & a small screwdriver to press the open leg of the male one in the pic slightly toward the other leg. When installed it's hard to tell which one is the open leg so press both & the one that moves is the open leg. When you have em depressed the right amount the terminal/wire will EASILY pull out the back side & if it wont you need more work especially on the female ones. Want that locking tab flat. dont force anything which will just end up damaging the bulkhead
Re: Extraction tool for electrical connector? [Re: RapidRobert] #1410895
03/30/13 12:11 PM
03/30/13 12:11 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Do you know where to get these connectors? I will need a few.
Re: Extraction tool for electrical connector? [Re: frank] #1410896
03/30/13 12:43 PM
03/30/13 12:43 PM
NAPA 725145-female. 725147- male. Premium brass terminals (Packard 56 type I believe). Pricey but that is a problem area that needs to be dealt with. Crimp & solder them onto the wires. EDIT On the female ones raise up the tab from flush so it will snap into place & lock it like a fishhook barb when you pull the pigtail assy into place. & before you install them check each & every one of the female ones by inserting a male one to check that the curved ears are bent just right & there's the right amount of tension for good contact but not too easy not too tight because when you are pressing the 2 bulkhead halves together is not the time to have male/female interface fitment issues when the brass terminals are already installed.
Re: Extraction tool for electrical connector? [Re: RapidRobert] #1410897
03/30/13 05:15 PM
03/30/13 05:15 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Thanks Robert. Just got back from NAPA with the correct parts. Appreciate the help
