8 3/4 leaking ??? #1410385
03/28/13 02:08 PM
03/28/13 02:08 PM
Calgary, Alberta Canada
a12rag Offline OP
a12rag  Offline OP
So I have cleaned/painted my housing, got the center section rebuilt with the original 3.23 gears and a sure-grip.
I noticed when I was cleaning the housing, that some of the studs for the pumpkin, were "worn" . . . the car must have been driven on a lot of gravel roads ??? . . . I cleaned up the studs as best I could with the die set and tapped the nuts . . . however, when I put it back together, some of the nuts would not torque up tight . . . I had used a bit of silcon and a gasket . . . all seemed ok. But after sitting for a while (still haven't moved the car - getting everything else together on it) I have noticed it is leaking from the bottom part of the center section/housing.
I was thinking I should just get some new nuts and see if they will torque up ? Or do I need to replace the studs in the housing. Of course all this happens AFTER you have installed EVERYTHING !!! So much easier when it is out of the car !! . . .
Thanks,
Mark
Re: 8 3/4 leaking ??? [Re: a12rag] #1410386
03/28/13 02:15 PM
03/28/13 02:15 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Change the nuts , if they still won't torque then you need to replace the studs .
Also make sure it's leaking from the gasket seam and not the weld seam underneath.
Did you use a gasket ?
When cleaning threads it's best to use thread chasers instead of taps and dies .
Re: 8 3/4 leaking ??? [Re: a12rag] #1410387
03/28/13 02:31 PM
03/28/13 02:31 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
If it t'was me...
I'd replace all studs together with new hardware...
I like a gasket(dry)...
Re: 8 3/4 leaking ??? [Re: RSNOMO] #1410388
03/28/13 02:40 PM
03/28/13 02:40 PM
a12rag Offline OP
a12rag  Offline OP
Yup, I did use a gasket and a thin layer of silicone on one side . . . am sure it is not leaking from the weld, but the gasket . . . so who would have the correct studs ??? Doctor Diff ?? . . .
Thanks,
Mark
Re: 8 3/4 leaking ??? [Re: a12rag] #1410389
03/28/13 02:51 PM
03/28/13 02:51 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Your call, but if it was me, I'd pull one out and make my way to the nearest auto parts, or some place that sells fasteners...
Re: 8 3/4 leaking ??? [Re: RSNOMO] #1410390
03/28/13 04:55 PM
03/28/13 04:55 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Edited because I was wrong. These are special studs. Sorry.
Re: 8 3/4 leaking ??? [Re: stumpy] #1410391
03/28/13 05:11 PM
03/28/13 05:11 PM
a12rag Offline OP
a12rag  Offline OP
No Ace Hardware up in my neck of the woods (Calgary Canada) . . .
Re: 8 3/4 leaking ??? [Re: JohnRR] #1410392
03/28/13 05:20 PM
03/28/13 05:20 PM
Change the nuts , if they still won't torque then you need to replace the studs.
X2 & if it works you dont have to open it up to get at the studs. EDIT if you have enough extra threads showing you might add a washer(s) before the nut so you end up on fresh(er) threads. All you need is for the nut to end up flush
Re: 8 3/4 leaking ??? [Re: a12rag] #1410393
03/28/13 07:32 PM
03/28/13 07:32 PM
Cab_Burge Online work
Cab_Burge  Online Work
Did you use thread sealer on the nuts and studs? If not try that first, get them really clean first though I had a similar issue reusing the original studs that had been removed to narrow the housing, just one or two of them leaked on the drivers side. Mopar use to install soft flat copper washers, maybe some other type of soft meatl also(CRS ) on a lot of the early cars, the washers would squish out and seal the threads, they where a bear to get off some times but they did help seal the unit up real well
Re: 8 3/4 leaking ??? [Re: a12rag] #1410394
03/28/13 07:32 PM
03/28/13 07:32 PM
JohnRR Offline
JohnRR  Offline
I would check with Dr. Diff for the studs.
Re: 8 3/4 leaking ??? [Re: JohnRR] #1410395
03/28/13 11:48 PM
03/28/13 11:48 PM
scratchnfotraction Offline
x2
Dr.Diff or Moser Engineering
Re: 8 3/4 leaking ??? [Re: scratchnfotraction] #1410396
03/30/13 09:50 AM
03/30/13 09:50 AM
a12rag Offline OP
a12rag  Offline OP
Cass said he has a stud/nut kit. Am gonna try the new nut route first. . . . Should be able to get those from local supply. Like the copper washer idea too - I even have those in the shop now !
Mark
Re: 8 3/4 leaking ??? [Re: a12rag] #1410397
03/30/13 10:09 AM
03/30/13 10:09 AM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
Not to Hijack,
but what is the proper way to install the new studs. I have to admit that pulling them in with the nuts did not end well for me.
Re: 8 3/4 leaking ??? [Re: belv2vert66] #1410398
03/30/13 10:20 AM
03/30/13 10:20 AM
a12rag Offline OP
a12rag  Offline OP
Good question . . . Aren't the originals swaged in place ?
Re: 8 3/4 leaking ??? [Re: a12rag] #1410399
03/30/13 02:23 PM
03/30/13 02:23 PM
No not swedged like wheel studs, I believe you just tap em out from the outside & drive new ones in from the inside
Re: 8 3/4 leaking ??? [Re: RapidRobert] #1410400
04/14/13 07:16 PM
04/14/13 07:16 PM
a12rag Offline OP
a12rag  Offline OP
Update . . . . got new nuts and copper washers, installed and looks like that fixed the leaking !! Everything tightened up great !!!
Re: 8 3/4 leaking ??? [Re: a12rag] #1410401
04/14/13 07:33 PM
04/14/13 07:33 PM
Thanks for letting us know, knowledge is power, and easier for someone else to use when it is posted like this
