8 3/4 leaking ???
#1410385
03/28/13 02:08 PM
03/28/13 02:08 PM
Posts: 2,922 Calgary, Alberta Canada
a12rag
So I have cleaned/painted my housing, got the center section rebuilt with the original 3.23 gears and a sure-grip.
I noticed when I was cleaning the housing, that some of the studs for the pumpkin, were "worn" . . . the car must have been driven on a lot of gravel roads ??? . . . I cleaned up the studs as best I could with the die set and tapped the nuts . . . however, when I put it back together, some of the nuts would not torque up tight . . . I had used a bit of silcon and a gasket . . . all seemed ok. But after sitting for a while (still haven't moved the car - getting everything else together on it) I have noticed it is leaking from the bottom part of the center section/housing.
I was thinking I should just get some new nuts and see if they will torque up ? Or do I need to replace the studs in the housing. Of course all this happens AFTER you have installed EVERYTHING !!! So much easier when it is out of the car !! . . .
Thanks,
Mark
Re: 8 3/4 leaking ???
[Re: JohnRR]
#1410392
03/28/13 05:20 PM
03/28/13 05:20 PM
RapidRobert
Change the nuts , if they still won't torque then you need to replace the studs.
X2 & if it works you dont have to open it up to get at the studs. EDIT if you have enough extra threads showing you might add a washer(s) before the nut so you end up on fresh(er) threads. All you need is for the nut to end up flush
[Re: a12rag]
#1410393
03/28/13 07:32 PM
03/28/13 07:32 PM
Posts: 43,293 Bend,OR USA
Cab_Burge
Did you use thread sealer on the nuts and studs? If not try that first, get them really clean first though I had a similar issue reusing the original studs that had been removed to narrow the housing, just one or two of them leaked on the drivers side. Mopar use to install soft flat copper washers, maybe some other type of soft meatl also(CRS ) on a lot of the early cars, the washers would squish out and seal the threads, they where a bear to get off some times but they did help seal the unit up real well
[Re: JohnRR]
#1410395
03/28/13 11:48 PM
03/28/13 11:48 PM
Posts: 15,487 Florida
scratchnfotraction
I would check with Dr. Diff for the studs.
x2
Dr.Diff or Moser Engineering
