Help selecting a wideband #1408800
03/25/13 07:24 PM
03/25/13 07:24 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
We want to tune my friends 418" six pack motor.
I'm looking for a wideband that can output A/F and RPM to a laptop for datalogging. I dont need it for a permanent install.
Any advice?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Help selecting a wideband [Re: AlexP] #1408801
03/25/13 07:32 PM
03/25/13 07:32 PM
WA
JD Dart Offline
JD Dart  Offline
WA
I have one Accel wideband comes with Drive line speed sensor two wideband sensors and two controllers. The one controller was ver 1 had to give it the ohms value for the sensor never did work write but I'll throw it in $350 for all of it. Went with Racepak is why I’m selling it.
best so far 8.53 @ 158.59 MPH 60'1.240
Re: Help selecting a wideband [Re: JD Dart] #1408802
03/26/13 04:32 PM
03/26/13 04:32 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Thanks but I'm hoping to get something that can feed from an inductive clamp or tach output.
Anyone else?
Re: Help selecting a wideband [Re: AlexP] #1408803
03/26/13 09:32 PM
03/26/13 09:32 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I don't know of any wide bands out there that do RPM.
I have an AEM wide band gauge that outputs a 5v signal (on sale at summit for $157 right now). I just hooked up with an Innovate Motorsports SSI-4 ($129) to log through the laptop
(which I also use to log boost, rpm, fuel pressure, and intake air temp).
You could get an LM-1 from innovate and hook it to an ssi-4 if you only wanted a temporary install... but wouldn't be much cheaper if at all.
Re: Help selecting a wideband [Re: dizuster] #1408804
03/26/13 10:18 PM
03/26/13 10:18 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
Actually the F.A.S.T. wideband has an upgrade where you can make it data log and it is RPM based. i have a dual sensor model and really like it. However the module itself is pretty bulky
edit: here is a pic of mine. the box on the left is the additional upgrade to make it data log. also has in inductive pickup or a tach pickup
Re: Help selecting a wideband [Re: prochargedhemi] #1408805
03/26/13 11:56 PM
03/26/13 11:56 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Innovate. http://www.innovatemotorsports.com/products/lm2.php
Good stuff but pricey.
Kevin
Re: Help selecting a wideband [Re: Twostick] #1408806
03/27/13 12:34 AM
03/27/13 12:34 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I use the FAST dual sensor along with the upgrade on my engine dyno every day. The upgrade includes an inductive clamp and a tachometer wire pickup . The inductive pickup is kind of cheap,but the tachometer read works good. When you do the upgrade package it lets you read the the playback in 1/2 of real time which is pretty handy. I am using mine to get pretty accurate readings for doing emulsion circuit tuning right now and couldn't be happier with it.
Keith
Re: Help selecting a wideband [Re: Dunnuck Racing] #1408807
03/27/13 04:57 PM
03/27/13 04:57 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
I have had both the fast and the innovative and prefer the innovative.
One day I will have something cool here.
Re: Help selecting a wideband [Re: sdaurity] #1408808
03/27/13 10:13 PM
03/27/13 10:13 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
AEM only!! 2 wire hookup. Clean simple. Works
Perfect
Innovate is very ground. Sensitive!!!!!
I trusted my 16psi 30 total true 11.0 cr e85 engine
To AEM!!!
74 dart sport 440 www.Csucarbs.com
