Ideas how to fix cat scratches on flat black hood ? #1408748
03/25/13 05:52 PM
03/25/13 05:52 PM
San Miguel NM
fowler1400 Offline OP
San Miguel NM
Got some light scratches on my 69RR flat black hood from cat claws,any ideas on how to remove them, I know not to try and polish out like regular paint ? Thanks for your help
Re: Ideas how to fix cat scratches on flat black hood ? [Re: fowler1400] #1408749
03/25/13 05:59 PM
03/25/13 05:59 PM
Not sure how to fix the damage that has already been done but I staked a pit bull in the yard close to my car & the cats stopped pissing on my tires/rims
Re: Ideas how to fix cat scratches on flat black hood ? [Re: fowler1400] #1408750
03/25/13 06:22 PM
03/25/13 06:22 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Start by barring the cat from near your car.
Re: Ideas how to fix cat scratches on flat black hood ? [Re: Challenger 1] #1408751
03/25/13 11:24 PM
03/25/13 11:24 PM
Harrisburg Pa. 17112
moparmikethree Offline
Shoot (Choot the cat JR) the cat. and then you'll have to reshoot the hood
Re: Ideas how to fix cat scratches on flat black hood ? [Re: moparmikethree] #1408752
03/25/13 11:46 PM
03/25/13 11:46 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I was watching this one, but it seems the jokes are currently OUTnumbering the helpful responses.
If the scratches are shallow enough, you may be in luck. I've had decent luck with Ajax cleanser and a wet towel. One drawback: You have to use it everywhere to maintain an even finish! You can't just scrub the affected area and hope that it blends.
Re: Ideas how to fix cat scratches on flat black hood ? [Re: Kern Dog] #1408753
03/26/13 08:20 AM
03/26/13 08:20 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
FWIW I just got some "Rat Wax" that was advertised in the last MCG. Don't know if it will wax out scratches but it's designed to clean and seal flat black finishes. I will be trying it when it warms up.
Re: Ideas how to fix cat scratches on flat black hood ? [Re: 63stabamatic] #1408754
03/26/13 01:25 PM
03/26/13 01:25 PM
dogdays Offline
dogdays  Offline
rub it with cat blood.
R.
Re: Ideas how to fix cat scratches on flat black hood ? [Re: dogdays] #1408755
03/26/13 04:34 PM
03/26/13 04:34 PM
P
Paul_Fancsali Offline
P
Try Lucas quick mist spray wax and really work it in the finish I have successfully used this on scratches that were in regualr black finish. Also Nano wax good for similar scratch
Re: Ideas how to fix cat scratches on flat black hood ? [Re: fowler1400] #1408756
03/26/13 04:58 PM
03/26/13 04:58 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Do you have any of the paint left that was used to spray the hood? If so I would use the pointed end of a round toothpick for a brush and very carefully try to fill the scratches. If you don't have any of the original paint get the closest match you can. After it drys thoroughly you should be able to blend it using fine scotchbrite and very gentle strokes. The key is not to get in a hurry and don't over do anything. It may not work, but so long as you don't go nuts and over do things it probably won't be any worse than it is now.
Re: Ideas how to fix cat scratches on flat black hood ? [Re: 5spdcuda] #1408757
03/26/13 11:29 PM
03/26/13 11:29 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
Is it a lacquer paint by chance? If they're really fine scratches I wonder if misting a coat of thinner on the whole hood would soften it enough to take the scratches out?
Re: Ideas how to fix cat scratches on flat black hood ? [Re: 6pkaar] #1408758
03/26/13 11:32 PM
03/26/13 11:32 PM
nj
N
notforsale440 Offline
N
nj
sand it and give it a fresh coat
Re: Ideas how to fix cat scratches on flat black hood ? [Re: fowler1400] #1408759
03/27/13 12:30 AM
03/27/13 12:30 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Flat black is IMO, impossible to repair by buffing or light touch up. A repaint more than likely.
I've wet sanded gloss black that my dog(s) messed up and it came out fine.
I might be worth trying a touch up first
Re: Ideas how to fix cat scratches on flat black hood ? [Re: 52savoy] #1408760
03/27/13 09:21 AM
03/27/13 09:21 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
You can try all of the suggestions but if it is flat black organisol either stripes or entire hood there isn't anyway to touch it up, it has to be re-shot. Sorry but that's just the way this stuff is.
You try to scuff or blend anything on flat it won't work. Flat cannot be buffed, or spotted or touched up, or waxed.You will still see it.
After you repaint it be sure and get a good car cover. That will keep the cat from hurting your paint.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Ideas how to fix cat scratches on flat black hood ? [Re: MOPARMIKE69] #1408761
03/27/13 08:03 PM
03/27/13 08:03 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
The car cover lets the kitties climb up the side of the car like spiderman
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Ideas how to fix cat scratches on flat black hood ? [Re: hemi-itis] #1408762
03/28/13 12:22 AM
03/28/13 12:22 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
black paste shoe polish and a soft horse hair brush
