Brakes soft while driving in reverse #1408409
03/25/13 03:22 AM
03/25/13 03:22 AM
Oak Forest, Texas
markshemiworld Offline OP
Oak Forest, Texas
So I have replaced the master cylinder, power booster, and both rear wheel cylinders. The car is a 1971 plymouth roadrunner with an aftermarket power front disk swap. (disks up front drums in rear). The kit uses what I believe to be a somewhat universal booster and GM master cylinder. The rear brakes are stock 8 3/4 drums. The pedal doesnt feel perfect in drive, but I havent had a problem with it being too soft, or having a lot of pedal travel. But the strangest thing happens when in reverse. Typically when I first get in my car and back out of the parking spot the pedal goes to the floor when I press it after ive moved a few feet. It does stop the car so I know it is applying some pressure, but I have to push the pedal extremely far and the pedal is very soft.
And when I put the car in drive and push the pedal twice it comes back up and the car stops fine and the pedal feels tons better. I checked the rear drum adjustment and the shoes are pretty tight against the drums. The master cylinder doesnt appear to be missing very much fluid at all. So I checked under the car, master cylinder, proportioning valves, steel lines, and rubber hoses, and I cant find any puddles or anything signifigant except some somewhat "wet" looking spots directly beneath the rear bleeding screws and around the connections on the rear wheel cylinders. Could air be seeping in through these spots and causing my symptoms? Anybody have any suggestions?
The steel brake lines were replaced with stainless lines 5 years ago, as well as the rubber lines.
Im thinking about having someone pressure bleed it with the master cylinder lid closed to find a leak if there is one. As always I appreciate any knowledge, experience, and helpful tips others have to offer. Full time college student working on this in my spare time.
Re: Brakes soft while driving in reverse [Re: markshemiworld] #1408410
03/25/13 09:50 AM
03/25/13 09:50 AM
Andrewh Online content
Andrewh  Online Content
that is odd.
the only thing I would think to do is run it in reverse apply the brakes only the once for it to go to the floor and then take apart the drum and see if the shoes shifted.
Re: Brakes soft while driving in reverse [Re: Andrewh] #1408411
03/25/13 10:01 AM
03/25/13 10:01 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
it definatly sounds like air,it doesnt take much.mabey the reason its worse in reverse is because once youve backed up the brakes are pumped enough where they work ok in forward.there should be NO wet spots anywhere.
Re: Brakes soft while driving in reverse [Re: markshemiworld] #1408412
03/25/13 10:26 AM
03/25/13 10:26 AM
tighten the connections that are "wet" till they are dry & just pushing the pedal will give you enough psi to confirm that they are now sealed up. then bleed the M/C then the 4 corners in order then holler back with where you're at. EDIT After rereading your post, after you get out of the parking lot they are sorta OK? I'm thinking the M/C may be bad but k.i.s.s. stop the leak(s) & rebleed & go from there
Re: Brakes soft while driving in reverse [Re: bonefish] #1408413
03/25/13 10:42 AM
03/25/13 10:42 AM
Franklin Co. Illinois
runinonmt Offline
runinonmt  Offline
"when I put the car in drive and push the pedal twice it comes back up"
You definitely have air in the system. In reverse you also lose the self-energising action of the rear drums. What you're doing is pumping the air to compress it similar to the method for bleeding. The air causes the spongy feeling because the compression isn't permanant. Bleed it some more.
Ron
In sixty-five I was seventeen and running up one-o-one I don't know where I'm running now, I'm just running on Jackson Browne-Running On Empty
Re: Brakes soft while driving in reverse [Re: runinonmt] #1408414
03/27/13 01:47 AM
03/27/13 01:47 AM
Oak Forest, Texas
Oak Forest, Texas
Thank yall for the fast responses. I havent had the time to perform the work myself in the past couple days so the car is going to a shop ive used before, tomorrow afternoon. I'll keep yall posted about the progess. Can you please elaborate more on the self-energizing action of the rear drums? Is this why in drive the front disks are doing the majority of the braking and I cant feel the spongyness as much? Because the self energizing action doesnt work in reverse and the air in the lines in the rear brakes is much more noticable?
Thanks again!
Re: Brakes soft while driving in reverse [Re: markshemiworld] #1408415
03/27/13 03:33 AM
03/27/13 03:33 AM
Castlegar, BC, Canada
That AMC Guy Offline
Drum brakes have a natural "self-applying" characteristic, better known as "self-energizing." The rotation of the drum can drag either one or both of the shoes into the friction surface, causing the brakes to bite harder, which increases the force holding them together. This increases the stopping power without any additional effort being expended by the driver, but it does make it harder for the driver to modulate the brake's sensitivity.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Brakes soft while driving in reverse [Re: That AMC Guy] #1408416
03/27/13 03:49 AM
03/27/13 03:49 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
I think the fronts have air, are they oriented proberbly {sp}?
--Daty
Re: Brakes soft while driving in reverse [Re: Daty Rogers] #1408417
03/31/13 02:23 AM
03/31/13 02:23 AM
Oak Forest, Texas
Oak Forest, Texas
So after returning the car to the shop to have them vacuum bleed the brakes, they told me that they got all the air out and that all connections were checked and tightened, and that the master cylinder was bad. The mechanic said that the master cylinder was allowing the piston to blow by. So the kit that I purchased is the Jegs power brake conversion kit, and to get another master cylinder I have to order it through them so I will have one here on wednesday. Also, they couldnt tell me what year model or part number so that I could get one at the auto parts store because their supplier makes them somewhat custom? But Jegs agreed to cover it under warantee. So I will keep yall posted on what happens next. Hopefully Ill have my car back by next weekend as this is my only car and I depend on it for my daily transportation. Thanks again guys!
Re: Brakes soft while driving in reverse [Re: markshemiworld] #1408418
04/05/13 05:03 PM
04/05/13 05:03 PM
Oak Forest, Texas
Oak Forest, Texas
So I went to pick up my car today and the brakes were still soft. That's with a new master cylinder and the brakes have been bled, and the rear wheel cylinders are new also. I do not know what else to check? Is it possible that I have the wrong rear wheel cylinders? I'm going to see if the mechanic can vacuum bleed the system and check for any leaks. Any ideas?
Re: Brakes soft while driving in reverse [Re: markshemiworld] #1408419
04/05/13 05:15 PM
04/05/13 05:15 PM
the brakes were still soft. Any ideas?
I'd check the round booster pushrod nub clearance to the bottom of the recess in the M/C rear piston "thimble" & you want .060" or a bit less. If good there I'd get 2 brass inverted flare male fittings from the "Edelman" cabinet at your parts house (they're cheap & you will reuse em) & cap the M/C & eng idling & if the M/C is good & bled out the pedal will be rock hard with virtually no travel then hookup 1 line & get it bled out & check that the drums are spooned up. We gotta start somewhere & might as well be at the beginning (booster/mc)
Re: Brakes soft while driving in reverse [Re: markshemiworld] #1408420
04/05/13 05:22 PM
04/05/13 05:22 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Have the shoes been adjusted out to the drums? This is one reason I like factory stuff.
Re: Brakes soft while driving in reverse [Re: 71birdJ68] #1408421
04/05/13 07:27 PM
04/05/13 07:27 PM
Oak Forest, Texas
Oak Forest, Texas
The master cylinder is brand new, and has been checked that it is good. The rear drum clearance has been checked and it is adjusted to be slightly grabbing. As far as the distance from the pushrod touching the master, that has also been adjusted to be very close. Could that be causing a problem? After driving it for awhile it feels sometimes like the pedal is very hard and stiff at the top with not much pressure needed to stop the car, while other times its soft with more pedal travel needed. Any more ideas? I agree about using factory stuff. The master and booster with the brackets they came with are the only non factory items I've used.
Re: Brakes soft while driving in reverse [Re: markshemiworld] #1408422
04/05/13 07:43 PM
04/05/13 07:43 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Do the front wheel bearings need to be adjusted? If they are loose the movement of the rotor will push the pistons into the caliper, like when you replace brake pads and you have to press the pedal a few times after pushing the piston all the way into the caliper.
Re: Brakes soft while driving in reverse [Re: Ply72rr] #1408423
04/05/13 09:48 PM
04/05/13 09:48 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
That's what I'm thinking after reading this. I had a rotor hat one time that was bent and caused the rotor to wobble back and forth. It pushes the piston back further than it should be and on the first pump of the brakes they were soft. Once pressure was there and if you rode the brake they were fine.
...FAFO...
Re: Brakes soft while driving in reverse [Re: skicker] #1408424
04/05/13 11:24 PM
04/05/13 11:24 PM
Oak Forest, Texas
Oak Forest, Texas
How could I tell if they needed to be adjusted? After driving it some tonight it seems very unpredictable as to when they will work and when the pedal travel is extremely far, and sometimes the pedal travel is short, but no matter how hard you push it struggles to stop the car. I am getting so confused by this. I'm open to all ideas
Re: Brakes soft while driving in reverse [Re: markshemiworld] #1408425
04/06/13 12:29 AM
04/06/13 12:29 AM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Jack the front end up and grabing tire at 12:00 & 6:00 try to rock the wheel. If there is any play they need to be tightened. To adjust them remove the cotter pin so you can turn the spindle nut. I turn it as tight as I can using a socket in my hand(no ratchet)while spinning the rotor, this will get it tight but not over preloaded. Hope this helps.
Re: Brakes soft while driving in reverse [Re: Ply72rr] #1408426
04/06/13 01:05 AM
04/06/13 01:05 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
on mopar cars mastercylinder the front line goes to the rear brakes and the rear line goes to the front brakes----chevys are opposite--front line(master) go to front brakes---i would check the lines to be sure they have not been crossed up...bob
Re: Brakes soft while driving in reverse [Re: savoy64] #1408427
04/06/13 01:56 PM
04/06/13 01:56 PM
Oak Forest, Texas
Oak Forest, Texas
Ok so this is a strong possibility because I know the shop built custom lines for the new master cylinder. I think they might be crossed, but how would I know for sure? I see they go from the master into a distribution block right below and how can I tell which line goes where?
