Brakes soft while driving in reverse
#1408409
03/25/13 03:22 AM
03/25/13 03:22 AM
Posts: 87 Oak Forest, Texas
markshemiworld
Oak Forest, Texas
So I have replaced the master cylinder, power booster, and both rear wheel cylinders. The car is a 1971 plymouth roadrunner with an aftermarket power front disk swap. (disks up front drums in rear). The kit uses what I believe to be a somewhat universal booster and GM master cylinder. The rear brakes are stock 8 3/4 drums. The pedal doesnt feel perfect in drive, but I havent had a problem with it being too soft, or having a lot of pedal travel. But the strangest thing happens when in reverse. Typically when I first get in my car and back out of the parking spot the pedal goes to the floor when I press it after ive moved a few feet. It does stop the car so I know it is applying some pressure, but I have to push the pedal extremely far and the pedal is very soft. And when I put the car in drive and push the pedal twice it comes back up and the car stops fine and the pedal feels tons better. I checked the rear drum adjustment and the shoes are pretty tight against the drums. The master cylinder doesnt appear to be missing very much fluid at all. So I checked under the car, master cylinder, proportioning valves, steel lines, and rubber hoses, and I cant find any puddles or anything signifigant except some somewhat "wet" looking spots directly beneath the rear bleeding screws and around the connections on the rear wheel cylinders. Could air be seeping in through these spots and causing my symptoms? Anybody have any suggestions? The steel brake lines were replaced with stainless lines 5 years ago, as well as the rubber lines. Im thinking about having someone pressure bleed it with the master cylinder lid closed to find a leak if there is one. As always I appreciate any knowledge, experience, and helpful tips others have to offer. Full time college student working on this in my spare time.
Re: Brakes soft while driving in reverse
[Re: Andrewh]
#1408411
03/25/13 10:01 AM
03/25/13 10:01 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
it definatly sounds like air,it doesnt take much.mabey the reason its worse in reverse is because once youve backed up the brakes are pumped enough where they work ok in forward.there should be NO wet spots anywhere.
[Re: markshemiworld]
#1408412
03/25/13 10:26 AM
03/25/13 10:26 AM
RapidRobert
tighten the connections that are "wet" till they are dry & just pushing the pedal will give you enough psi to confirm that they are now sealed up. then bleed the M/C then the 4 corners in order then holler back with where you're at. EDIT After rereading your post, after you get out of the parking lot they are sorta OK? I'm thinking the M/C may be bad but k.i.s.s. stop the leak(s) & rebleed & go from there
[Re: bonefish]
#1408413
03/25/13 10:42 AM
03/25/13 10:42 AM
Posts: 416 Franklin Co. Illinois
runinonmt
"when I put the car in drive and push the pedal twice it comes back up" You definitely have air in the system. In reverse you also lose the self-energising action of the rear drums. What you're doing is pumping the air to compress it similar to the method for bleeding. The air causes the spongy feeling because the compression isn't permanant. Bleed it some more. Ron
In sixty-five I was seventeen and running up one-o-one
I don't know where I'm running now, I'm just running on
Jackson Browne-Running On Empty
#1408415
03/27/13 03:33 AM
03/27/13 03:33 AM
Posts: 4,798 Castlegar, BC, Canada
That AMC Guy
Drum brakes have a natural "self-applying" characteristic, better known as "self-energizing." The rotation of the drum can drag either one or both of the shoes into the friction surface, causing the brakes to bite harder, which increases the force holding them together. This increases the stopping power without any additional effort being expended by the driver, but it does make it harder for the driver to modulate the brake's sensitivity.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
#1408425
04/06/13 12:29 AM
04/06/13 12:29 AM
Posts: 553 DE
Ply72rr
DE
How could I tell if they needed to be adjusted? After driving it some tonight it seems very unpredictable as to when they will work and when the pedal travel is extremely far, and sometimes the pedal travel is short, but no matter how hard you push it struggles to stop the car. I am getting so confused by this. I'm open to all ideas
Jack the front end up and grabing tire at 12:00 & 6:00 try to rock the wheel. If there is any play they need to be tightened. To adjust them remove the cotter pin so you can turn the spindle nut. I turn it as tight as I can using a socket in my hand(no ratchet)while spinning the rotor, this will get it tight but not over preloaded. Hope this helps.
