Bled brakes still don't have hard pedal #1408206
03/24/13 07:09 PM
03/24/13 07:09 PM
martinsburg, w.v.
416scamp Offline OP
416scamp  Offline OP
martinsburg, w.v.
Did a disc brake changeover from SSBC. Bench bled the master cylinders hen installed, bled all 4 wheels starting from furthest one from master cylinder.. Still no hard pedal. What do you guys think I'm doing wrong? Any help would be appreciated
Re: Bled brakes still don't have hard pedal [Re: 416scamp] #1408207
03/24/13 07:13 PM
03/24/13 07:13 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
are all of the lines new? possibly cracked or lose fitting letting air in? I had the same problem on my roadrunner. the bleeders seemed to bleed out fine only to have a soft pedal. got looking and found brake fluid oozing out of the fitting that goes down to the axle.
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: Bled brakes still don't have hard pedal [Re: 416scamp] #1408208
03/24/13 07:48 PM
03/24/13 07:48 PM
Do they pump up? If so there's still air in there. M/C might be bad & is this the same M/C or a new one? Might purchase 2 brass male inverted flare fittings (they're cheap & you will reuse em) from the Edelman fittings cabinet at your parts house & cap the M/C ports. If the M/C is good (& bled out) the pedal will be rock hard with virtually no travel. If good there then you can hookup 1 line & rebleed that half out & if you now have a hard pedal the problem is in the other half. Holler how it turns out. EDIT if the air is in the front discs & you cant clear them you might have to take the caliper off & tilt it as the bleeder might be at 12 0'clock but the passage from the bleeder down to the bore must meet the bore at 12 0'clock. Sometimes stomping the pedal several times then you open the bleeder at the exact time the helper is on the 4th downward stomp will agitate the fluid enough to get the last remnants of air out & be sure to tighten the bleeders enough so air ain't drawn back in on the upstroke DAMHIK on that bonehead mistake
Re: Bled brakes still don't have hard pedal [Re: RapidRobert] #1408209
03/24/13 07:54 PM
03/24/13 07:54 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Did you mount the calipers in the proper position?
I am truckless..
Re: Bled brakes still don't have hard pedal [Re: 340SHORTY] #1408210
03/24/13 10:04 PM
03/24/13 10:04 PM
martinsburg, w.v.
416scamp Offline OP
416scamp  Offline OP
martinsburg, w.v.
Thanks for the reply guys. Calipers are mounted properly. Using all the original lines. Installed a proportion valve is the only thing I changed in line. Thanks again guys. Will let you know how it turns out....
Re: Bled brakes still don't have hard pedal [Re: 416scamp] #1408211
03/24/13 11:21 PM
03/24/13 11:21 PM
does it have the little pin valve that needs to be pulled (& held) out while you're bleeding?
Re: Bled brakes still don't have hard pedal [Re: RapidRobert] #1408212
03/25/13 04:15 PM
03/25/13 04:15 PM
martinsburg, w.v.
416scamp Offline OP
416scamp  Offline OP
martinsburg, w.v.
. Didn't notice a pin or anything. Just the knob to increase or decrease pressure.
Re: Bled brakes still don't have hard pedal [Re: 416scamp] #1408213
03/25/13 04:37 PM
03/25/13 04:37 PM
Oh OK, an OE prop valve MAY have the pin which needs to be opened (pulled out) to bleed & you have an aftermarket adjustable prop valve in the rear line. I would have it all the way open (increased psi) to bleed but I dont think that's the problem
Re: Bled brakes still don't have hard pedal [Re: RapidRobert] #1408214
03/25/13 07:56 PM
03/25/13 07:56 PM
martinsburg, w.v.
416scamp Offline OP
416scamp  Offline OP
martinsburg, w.v.
Do they pump up? If so there's still air in there. To answer your question earlier is yes they will pump up..
Re: Bled brakes still don't have hard pedal [Re: 416scamp] #1408215
03/25/13 09:31 PM
03/25/13 09:31 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Plug the outlets at the master cylinder. If the pedal is hard then there is still air in the lines. You can do the same at the dist block by shutting off front or rear lines with a plug. That will isolate which circuit is causing the cussing. On a new empty system it can be a [Edited by Moparts - Family Friendly Site - Keep it clean]. I've had to bleed 4-5 times to get all the air out. Speed bleeders or a catch tank with the one way check valve help a lot. Also, make sure you have adjusted the rear brakes if they are drums.
Re: Bled brakes still don't have hard pedal [Re: Lefty] #1408216
03/27/13 12:05 AM
03/27/13 12:05 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Exactly! If the shoes have to travel too far to meet the drum, you won't get a hard pedal.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Bled brakes still don't have hard pedal [Re: GO_Fish] #1408217
03/27/13 09:53 PM
03/27/13 09:53 PM
martinsburg, w.v.
416scamp Offline OP
416scamp  Offline OP
martinsburg, w.v.
Used vacuum pump and couldn't really get anything to come out of the rear bleeders.. And also my other question is does it matter if I mounted the proportion valve with the knob pointed to ground instead in up right position?
Re: Bled brakes still don't have hard pedal [Re: 416scamp] #1408218
03/27/13 10:05 PM
03/27/13 10:05 PM
No problem there
Re: Bled brakes still don't have hard pedal [Re: 416scamp] #1408219
03/27/13 10:08 PM
03/27/13 10:08 PM
st.cloud fl
d-150 Online content
Smarter than a 5th grader?
d-150  Online Content
st.cloud fl
i just did my jeep close bleeder,pump vacuum up open bleeder,repeat. i got just dribble.went to front bleed both sides that centered valve.went to back and bled started to get alot of fluid.if the valve is not centered sometimes they are stubborn.also i seen the valves mounted sideways but never upsidedown so dont know if that makes a difference
Re: Bled brakes still don't have hard pedal [Re: d-150] #1408220
03/27/13 10:14 PM
03/27/13 10:14 PM
martinsburg, w.v.
416scamp Offline OP
416scamp  Offline OP
martinsburg, w.v.
Thanks for the replys guys.. Gonna mess with it in the morning
Re: Bled brakes still don't have hard pedal [Re: 416scamp] #1408221
03/27/13 10:50 PM
03/27/13 10:50 PM
Unfortunately back in New York
N
Nukechargerboy Offline
N
I went through this on a 4 wheel ssbc setup. Took along time to get the bubbles out. I went through about 2 quarts of brake fluid with a power bleeder and it still took a while. Patience.
Re: Bled brakes still don't have hard pedal [Re: Nukechargerboy] #1408222
03/30/13 10:41 PM
03/30/13 10:41 PM
martinsburg, w.v.
416scamp Offline OP
416scamp  Offline OP
martinsburg, w.v.
How long is a while? Ive been doing it for 3 days and still no hard pedal.. Ive done everything, cant find any leaks anywhere, ive even put another M/C on today. Ive bled brakes before with no problem, but this sure is not working this time. Im at wits end..Im no mechanic but i try to do and learn everything I can myself especially to save some money, but i guess im gonna have to get some help this time.. Maybe i will take a few days away from it then try it again..
Re: Bled brakes still don't have hard pedal [Re: 416scamp] #1408223
03/30/13 11:04 PM
03/30/13 11:04 PM
I'd consider capping the M/C with 2 brass Edelman inverted flare plug & see if the M/C is good/bled then hookup one half. this'll help you narrow the problem down & make some progress. Holler how it goes
Re: Bled brakes still don't have hard pedal [Re: RapidRobert] #1408224
03/31/13 09:26 AM
03/31/13 09:26 AM
Amherst,NY
challengermike Offline
Amherst,NY
you probably need a Residual Pressure Valve in the rear line if your running rear drum brakes. If its an aftermarket prop valve it may not be built into it.
Re: Bled brakes still don't have hard pedal [Re: challengermike] #1408225
03/31/13 10:01 AM
03/31/13 10:01 AM
Slidell, LA
Plum440 Offline
Plum440  Offline
Slidell, LA
Needed one in mine and after the pads on the front finally seated the pedal firmed up. Also, pushrod on MC had to be adjusted.
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
