Re: What should I check next? [Re: sixpackgut] #1408117
03/25/13 11:06 PM
03/25/13 11:06 PM
Lehigh Acres, Florida
rickstershemi Offline
i broke 3 fins (for lack of a better term) off the reluctor in my MSD Dizzy once after a hard landing on a higher than normal wheelie.....instantly ran like crap with three cyl down...????
Rickster
amazing
go figure.....found three cold header tubes trying to figure it out and when we went to ck the cap/rotor....found them lying in the dizzy MSD did swap out a brand new dizzy at zero cost
Rickster
Re: What should I check next? [Re: 70Dart499] #1408118
03/25/13 11:29 PM
03/25/13 11:29 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
Check the ignition stuff over this evening, and everything seems OK, I'm borrowing a leak down tester from a friend tomorrow, and we are going to check the comp. Im thinking its a blown head gasket since the two middle cylinders are dead. I'm kind of hoping thats all it is, becuase I can fix it in one or two evenings work.
from your description the head gasket would be my first guess, if this has aluminum heads the head may need repair.
Re: What should I check next? [Re: jamesc] #1408119
03/26/13 01:06 AM
03/26/13 01:06 AM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
I still would think it is ignition, sounds like is not firing on those cylinders at all. I would change cap,rotor and wires first. A blown head gasket would more than likely have water in the oil or be throwing some water out the headers. poppaj
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: What should I check next? [Re: poppaj] #1408120
03/26/13 01:08 AM
03/26/13 01:08 AM
jamesc Offline
jamesc  Offline
not if it's blown between the cylinders which is a common failure point...no water there
Re: What should I check next? [Re: jamesc] #1408121
03/26/13 01:25 AM
03/26/13 01:25 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I think we can agree that it's not a fuel problem...
Is the battery fully charged? Check for spark at 4 and 6.
What changes have been made recently, no matter how unrelated?
Re: What should I check next? [Re: RodStRace] #1408122
03/26/13 08:52 AM
03/26/13 08:52 AM
ill
dennismopar73 Offline
ill
Start with timing,and rotor phasing!! bet the spark is 'blowing off, balancer may have slipped as they do and thus the spark blow off,
start from fresh pull it upon number 1 , check the balancer!!!!
then the rotor phasing!!
I will bet you have more than 1 or 2 cyl that is running colder!!
Re: What should I check next? [Re: jamesc] #1408123
03/26/13 09:28 AM
03/26/13 09:28 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
If #4 and #6 plug wires aren't crossed, I would suspect the head gasket blown between those cylinders.
If you like drag racing, support your local track.
Re: What should I check next? [Re: CHAPPER] #1408124
03/26/13 09:49 AM
03/26/13 09:49 AM
Guitar Jones Offline
I guess I read it wrong, I thought it was 2 & 6, I would have to agree, do a compression test. All the other ignition stuff would affect other cylinders also, not just 2. Process of elimination, eliminate everything else except what would only affect 2 cylinders, and in this case 2 adjacent cylinders.
Re: What should I check next? [Re: Guitar Jones] #1408125
03/26/13 10:23 AM
03/26/13 10:23 AM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
Problem is in carb. Its dumping fuel and the manifold is directing it into those two cylinders.
If it were a head gasket, it would be popping up thru carb as pressure passed between cylinders.
Good Luck
Re: What should I check next? [Re: TheBlackCar] #1408126
03/26/13 02:20 PM
03/26/13 02:20 PM
Plant city fl
70Dart499 Offline OP
Plant city fl
Good Luck
I guess I forgot to mention that it is popping out of the carb a bit
1970 Dart Drag Car
Re: What should I check next? [Re: 70Dart499] #1408127
03/31/13 03:07 PM
03/31/13 03:07 PM
Plant city fl
Plant city fl
Well, got the head off today and its not good. The head gasket was blown, and the head has a decent size gouge where the gasket blew. So I guess I will have to have that one resurfaced, and I assume I'll have to pull the other one and have it resurfaced also. I hope not, but im going to call the machinist in the morning and I'm sure he is going to suggest doing both heads. I guess I will be bracket racing my pickup truck for a while, because I'm sure the machine work ain't gonna be cheap
1970 Dart Drag Car
