Re: What should I check next?
[Re: sixpackgut]
#1408117
03/25/13 11:06 PM
03/25/13 11:06 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
i broke 3 fins (for lack of a better term) off the reluctor in my MSD Dizzy once after a hard landing on a higher than normal wheelie.....instantly ran like crap with three cyl down...????
Rickster
amazing
go figure.....found three cold header tubes trying to figure it out and when we went to ck the cap/rotor....found them lying in the dizzy MSD did swap out a brand new dizzy at zero cost
Rickster
[Re: 70Dart499]
#1408118
03/25/13 11:29 PM
03/25/13 11:29 PM
Posts: 5,875 communist bloc of new jersey
jamesc
Check the ignition stuff over this evening, and everything seems OK, I'm borrowing a leak down tester from a friend tomorrow, and we are going to check the comp. Im thinking its a blown head gasket since the two middle cylinders are dead. I'm kind of hoping thats all it is, becuase I can fix it in one or two evenings work.
from your description the head gasket would be my first guess, if this has aluminum heads the head may need repair.
[Re: poppaj]
#1408120
03/26/13 01:08 AM
03/26/13 01:08 AM
jamesc
I still would think it is ignition, sounds like is not firing on those cylinders at all. I would change cap,rotor and wires first. A blown head gasket would more than likely have water in the oil or be throwing some water out the headers. poppaj
not if it's blown between the cylinders which is a common failure point...no water there
[Re: RodStRace]
#1408122
03/26/13 08:52 AM
03/26/13 08:52 AM
Posts: 2,177 ill
dennismopar73
ill
Start with timing,and rotor phasing!! bet the spark is 'blowing off, balancer may have slipped as they do and thus the spark blow off, start from fresh pull it upon number 1 , check the balancer!!!! then the rotor phasing!!
I will bet you have more than 1 or 2 cyl that is running colder!!
[Re: jamesc]
#1408123
03/26/13 09:28 AM
03/26/13 09:28 AM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
If #4 and #6 plug wires aren't crossed, I would suspect the head gasket blown between those cylinders.
If you like drag racing, support your local track.
[Re: CHAPPER]
#1408124
03/26/13 09:49 AM
03/26/13 09:49 AM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
I guess I read it wrong, I thought it was 2 & 6, I would have to agree, do a compression test. All the other ignition stuff would affect other cylinders also, not just 2. Process of elimination, eliminate everything else except what would only affect 2 cylinders, and in this case 2 adjacent cylinders.
