stamped steel rockers or adjustable 273 rockers #1408092
03/24/13 06:20 PM
03/24/13 06:20 PM
CHULA VISTA , CA
J_GAMALA Offline OP
J_GAMALA  Offline OP
CHULA VISTA , CA
what is the advantage of using the adjustable ones?
mopar perf 284 484 purple cam
Re: stamped steel rockers or adjustable 273 rockers [Re: J_GAMALA] #1408093
03/24/13 06:48 PM
03/24/13 06:48 PM
IN
ahy Offline
ahy  Offline
IN
The adjustables allow you to dial in the pre-load exactly and can take a bit more spring load and lift. With the 284, either should work. If running the stamped rockers, pushrod length will need to be dialed in carefully to get correct pre-load.
Re: stamped steel rockers or adjustable 273 rockers [Re: ahy] #1408094
03/24/13 06:54 PM
03/24/13 06:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I wouldnt even think old the stock rockers unless
it was a totally stock rebuild
Re: stamped steel rockers or adjustable 273 rockers [Re: MR_P_BODY] #1408095
03/24/13 07:01 PM
03/24/13 07:01 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
The durability goes up by a factor of 10,000 when stepping up from stamped steel.
The H.D. are better , but the stock ones are worth around .04 a pound.
Re: stamped steel rockers or adjustable 273 rockers [Re: J_GAMALA] #1408096
03/24/13 08:12 PM
03/24/13 08:12 PM
B.C. Canada
hankcrank Offline
hankcrank  Offline
B.C. Canada
If you plan to use stiffer H.D valve springs the push rods could eventually push through the rocker arm cup.It happened to me cost me a race lol. good luck
