Re: How to "LOCK" small block distributor
[Re: moparmikethree]
#1407978
03/24/13 05:00 PM
03/24/13 05:00 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
Weld the 2 pins on the weights to the slotted part where the weights are attached. Or go with a later model one from a lean burn that is already locked. That's what I used for my EFI conversion.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: Challenger 1]
#1407982
03/24/13 06:41 PM
03/24/13 06:41 PM
RapidRobert
I wouldn't either but if you do first drill a 1/2" hole in the dist cap flat 2/3 of the way between the center terminal and the #1 cap terminal so you can check rotor phasing with your timing light & run the dist & pump up the vac adv gradually with a Mityvac till the rotor phasing is dead on & note the in hg on the gauge then on your bench pump in that amt of vacuum & drill a vertical hole thru both plates in an appropriate location & lock em together in that position with a bolt/nut & use a spacer on the mini bolt inbetween the plates so they stay parallel when you tighten the nut. Then can remove the vac can & cover the hole in the side of the dist with a plate or keep it there to cover the hole. Not sure what to do on the weights but others have commented on that
#1407983
03/25/13 01:06 AM
03/25/13 01:06 AM
Posts: 1,822 Colorado
denfireguy
Colorado
Because of my engine combo, my Machine shop/Engine builder suggested that I LOCK my small block distributor.
What he wants to try is run about 34-36 timing all the time. remove the weights and the vacuum advance.Advance the pic-up plate, and then lock it. I have a lot of distributors so i don't mind messing with one or two.
Can't find this anywhere on the net. does anyone know how to do this?
Thanks Mike
If you want to try this first, find a lean burn distributor. There must be a bunch of them around since everyone wants to change them back to vacuum and mechanical advance. I would not muck up a good distributor for a project that you may want to go back on. Then again, the new billet distributor may be the way to go if you need advance again. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#1407984
03/25/13 09:19 AM
03/25/13 09:19 AM
Posts: 2,177 ill
dennismopar73
ill
You can buy new lean burn plates at any auto parts store! Yes they work just fine,as I have used in them for years, Not ideal if you are looking for fuel mileage,but if it is a performance car,,fuel mileage is the last thing you do worry about! as for rotor phasing ,you can drill holes as mentioned ,or buy a see thru cap , I have made my own rotors to compensate for the off rotor phasing,and most times , the 'bug' can be ground to make up most the issues,
[Re: 80fbody]
#1407987
03/25/13 10:31 AM
03/25/13 10:31 AM
Challenger 1
Cincinnati, Ohio
A little JB Weld in the slot does the trick. nothing fancy. Works great. Ran my small block on the street like that for years. One less thisng to deal with. Once you set it, there's never a thought about advance, springs, etc. No starter issues either. Certainly may not be the best for a high compression motor but a street car with a mini starter will be just fine.
And I'll bet you my motor runs better than yours.
[Re: Challenger 1]
#1407988
03/25/13 12:37 PM
03/25/13 12:37 PM
Posts: 596 Mass.
80fbody
Mass.
Would you like a sticker? You sound like a 4 year old. Good job.
O.P., I only changed the plugs once or twice in nearly ten years of that motor. I never really had any issues with it. I did actually switch to a well curved distributor but my car really liked all the timing from idle. It was a .509 cammed small block. It did tend to idle a little higher (1000 rpms)but that really was the only thing I can think of. It may have been the advance on the cam as well. Having extra distibutors, I'd try it for the cost of some JB weld. Heck, that stuff's fun. Good Luck.
[Re: 80fbody]
#1407989
03/25/13 12:45 PM
03/25/13 12:45 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
On a race car, meaning basically a narrow throttle and rpm window, a locked out ignition is fine and it eliminates a lot of worry or potential for surprises. But if your car has to run pump fuel, idle, run at light, part, and full throttle, and rpms from 700 to 6+ over the course of a summer - the right set of ignition advances will work much better. No engine "likes" a single timing setting for any more than a single throttle opening and rpm range. no sticker needed here. Just my opinion.
