1970 Challenger kick panel insulation #1407171
03/23/13 04:53 PM
03/23/13 04:53 PM
Wausau Wisconsin USA North Ame...
radiatorman Offline OP
Hi Guys,
Can anyone tell me if I have the insulation pieces positioned correctly on the kick panels? And where the heck do the two other pieces of backed insulation go? I marked one "d kick panel" and purposely left the screw in it to remind me where it goes (5 years ago) but I can't remember now. Any good pictures out there??
Thanks,
Bob
Re: 1970 Challenger kick panel insulation [Re: radiatorman] #1407172
03/23/13 05:17 PM
03/23/13 05:17 PM
Hamtramck, PA
Alaskan_TA Online content
Fluffy Balladeer
Alaskan_TA  Online Content
Fluffy Balladeer
Hamtramck, PA
Re: 1970 Challenger kick panel insulation [Re: Alaskan_TA] #1407173
03/23/13 05:18 PM
03/23/13 05:18 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
2
Re: 1970 Challenger kick panel insulation [Re: radiatorman] #1407174
03/23/13 06:30 PM
03/23/13 06:30 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Since Alaskan T/A has the kick panels covered, the pieces you currently show in the kick panels should be installed in the dash structure (Just above the kick panels) you'll see them in the upper corners of the photo's I have attached. I can outline them if you need but think you'll find it pretty self explanatory, if not, let me know.
Re: 1970 Challenger kick panel insulation [Re: AAR#2] #1407175
03/23/13 06:31 PM
03/23/13 06:31 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
heres the pass side.
Re: 1970 Challenger kick panel insulation [Re: AAR#2] #1407176
03/25/13 09:44 AM
03/25/13 09:44 AM
Thanks guys!!
Re: 1970 Challenger kick panel insulation [Re: radiatorman] #1407177
03/25/13 09:58 AM
03/25/13 09:58 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Here's my pictures just for fun.
Re: 1970 Challenger kick panel insulation [Re: AAR#2] #1407178
01/04/14 03:30 AM
01/04/14 03:30 AM
California, USA
filmsurgeon Offline
filmsurgeon  Offline
California, USA
Doing my insulation now. The REM kick-panel kit I got several years ago has 3 pieces; the 2 larger pieces which is self explanatory, and the piece for the backside of driver-side kick panel, not one the for the passenger side. Any ideas where I can get the passenger side piece? How were they secured to the backside of the kick-panels? Also, does anyone know if the two oddly shaped pieces that go "above the kick panels" (as AAR#2 pictured) are being reproduced? Thanks for the help.
Re: 1970 Challenger kick panel insulation [Re: filmsurgeon] #1407179
01/04/14 01:10 PM
01/04/14 01:10 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
I sent all my pieces in to Detroit Muscle and he was nice enough to correct and cut new pieces that match my originals. Unsure if this is the standard cut for him now but he should have mine on file
Contact him, I'm sure he can hook you up
Re: 1970 Challenger kick panel insulation [Re: AAR#2] #1407180
01/04/14 05:03 PM
01/04/14 05:03 PM
California, USA
filmsurgeon Offline
filmsurgeon  Offline
California, USA
Thanks. I contacted Jim via email last night. I have purchased DMT stuff before, and have worked with Jim on a couple of my special needs. Hopefully, he can help. I know he is always very busy.
Re: 1970 Challenger kick panel insulation [Re: filmsurgeon] #1407181
01/04/14 08:06 PM
01/04/14 08:06 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Hey Joe,
Yep I can make you a correct set. AAR2 shows the correct location of the small pieces that go above the kickpanels, the large pieces that stuff in the body and then there are 2 more pieces that glue to the backs of the kick panels. None of these pieces are symmetrical.
I'm working on a a complete line of the firewall and kickpanel insulation pieces. Working on duplicating the embossed, tar paper like material. Ordered a semi load of the correct insulation. Hope to have most of the popular pieces by Carlisle.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
