Code P0452 Evap Emis Sys 04 Durango ????? #1407040
03/23/13 11:33 AM
03/23/13 11:33 AM
Holly/MI
Dean_Kuzluzski Offline OP
Holly/MI
As mentioned, got a P0452 code in the wifes 04 Dodge Durango.
It looks to be related to the pressure sensor that vents fumes to the evap. emission system (vapor canistor).
Just wondering what the experienced dealer mechanics have encountered with this other than the obvious conclusion that the sensor is bad?? It appears to be part-of-assembly to the fuel sending/pump unit in the tank.
The sensor isn't available separately from what AZ tells me.
Any info is appreciated.
Re: Code P0452 Evap Emis Sys 04 Durango ????? [Re: Dean_Kuzluzski] #1407041
03/23/13 12:12 PM
03/23/13 12:12 PM
Manitoba, Canada
fjmg Offline
fjmg  Offline
Manitoba, Canada
I have never worked on a durango but my buddy had an 05 focus that came up with an evaporative code (cannot remember which one) and after some reading found that the air line between the filler cap and the cannister next to the tank likes to plug with spiders nest (seriously, that's what I read). The solution was to disconnect at the canister and use compressed air at a low pressure to clear it. Code never returned.
Of course you are sure the filler cap is sealing right?
Re: Code P0452 Evap Emis Sys 04 Durango ????? [Re: fjmg] #1407042
03/23/13 12:33 PM
03/23/13 12:33 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
has it had a fuel pump recently? if you have a scanner you can command the vent sol on or off and see if its actually working. you may have to go to the dealer for it, or it may be part of the fuel pump assy. when it comes to engine management AZ would be the last place I went, unless of course you dont mind doing it again in a month. Unfortunately it will need to be checked out, evap sucks to debug without the correct equipment.
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Code P0452 Evap Emis Sys 04 Durango ????? [Re: fjmg] #1407043
03/23/13 12:37 PM
03/23/13 12:37 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Make sure the cap is sealing well as mentioned before. Probably just a split EVAP hose. This is very common. Check for this at the throttle body, EVAP check port, purge solenoid, and charcoal canister for a bad hose.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Code P0452 Evap Emis Sys 04 Durango ????? [Re: 71yelladustr] #1407044
03/23/13 04:16 PM
03/23/13 04:16 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
this , I had the same thing on my Grand cherokee , hose ...
Re: Code P0452 Evap Emis Sys 04 Durango ????? [Re: JohnRR] #1407045
03/23/13 04:32 PM
03/23/13 04:32 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
p0452 means the computer has not seen the switch close(NLVD) when vacuum was applied. (90%) time it's from a crack in the hoses.
Re: Code P0452 Evap Emis Sys 04 Durango ????? [Re: SALEM1912] #1407046
03/23/13 05:21 PM
03/23/13 05:21 PM
Holly/MI
Holly/MI
OK, I'll check out the plumbing from the throttle body to the canister purge. The fuel fill cap works fine, but will take another look.
Thanks to ALL!!
Re: Code P0452 Evap Emis Sys 04 Durango ????? [Re: Dean_Kuzluzski] #1407047
03/23/13 06:21 PM
03/23/13 06:21 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
P0452 NVLD Pressure Switch Stuck Closed - With Automatic Transmission
Possible Causes Setting Conditions
EVAP purge solenoid control circuit is shorted to ground
NVLD assembly has failed (the switch may be stuck closed)
NVLD connector is damaged (check pins for damage, and for moisture)
NVLD switch signal circuit is shorted to ground
PCM has failed
Vac Leak
Engine started; and immediately after engine startup, the PCM activates the NVLD solenoid to test the NVLD switch circuit. If the PCM does not detect that the switch is open under these conditions, DTC P0452 is set.
This code sets in 2 Trip(s).
This code will turn on the MIL (Malfunction Indicator Lamp)
Re: Code P0452 Evap Emis Sys 04 Durango ????? [Re: Dakota_Don] #1407048
03/23/13 06:25 PM
03/23/13 06:25 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
not sure if this helps
Re: Code P0452 Evap Emis Sys 04 Durango ????? [Re: Dakota_Don] #1407049
03/24/13 08:11 AM
03/24/13 08:11 AM
Holly/MI
Holly/MI
This ALL helps a lot! Thank you.
My first guess is it's probably a vacuum leak. The fuel tank has never been down and otherwise there should be no damage to the wiring but you never know until one gets out there and probes around with a multimeter.
I have a pretty good professional background in automotive electrical troubleshooting, but no access to the particular tech info, so all that info is a great start.
Thanks again!
Dean
Re: Code P0452 Evap Emis Sys 04 Durango ????? [Re: Dean_Kuzluzski] #1407050
03/24/13 02:49 PM
03/24/13 02:49 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
what was it? bad wiring? or solenoid? vac leak?
