833 Transmission id-numbers #1406076
03/21/13 01:52 PM
03/21/13 01:52 PM
Moncton, New Brunswick
hemidart1 Offline OP
Can anyone help me out to i.d. this tranny-ie: what year etc..
1967 Hemi GTX
1969 Chrysler 300
Re: 833 Transmission id-numbers [Re: hemidart1] #1406077
03/21/13 02:00 PM
03/21/13 02:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Look for a raised pad on the passenger side of the main case, it'll have the build data stamped in it.
Re: 833 Transmission id-numbers [Re: John_Kunkel] #1406078
03/21/13 02:09 PM
03/21/13 02:09 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The numbers posted are basically useless in any kind of identification process ...
That said it looks like the 71 up side cover , also looks like an 82 date code on the cover , so it could be an OD trans
Re: 833 Transmission id-numbers [Re: JohnRR] #1406079
03/21/13 02:12 PM
03/21/13 02:12 PM
ok
1967 Hemi GTX
1969 Chrysler 300
Re: 833 Transmission id-numbers [Re: hemidart1] #1406080
03/21/13 02:14 PM
03/21/13 02:14 PM
JohnRR Offline
JohnRR  Offline
What info are you trying to find out ?
Re: 833 Transmission id-numbers [Re: JohnRR] #1406081
03/21/13 02:38 PM
03/21/13 02:38 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Looks like a early 80's alum main truck/van overdrive
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: 833 Transmission id-numbers [Re: Dan Brewer] #1406082
03/21/13 02:56 PM
03/21/13 02:56 PM
JohnRR Offline
JohnRR  Offline
Assuming it's never been messed with
Re: 833 Transmission id-numbers [Re: JohnRR] #1406083
03/21/13 08:38 PM
03/21/13 08:38 PM
I am looking for my Charger-the guy is selling it with an adapted bell housing to fit a Chevy. I would ditch the bell housing if it is a correct trans.
more pics:
[image]
1967 Hemi GTX
1969 Chrysler 300
Re: 833 Transmission id-numbers [Re: hemidart1] #1406084
03/21/13 08:42 PM
03/21/13 08:42 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
In the 80's GM put the A833 in Chevy trucks. I have no idea what they did you make it work but I would at the least make sure the input shaft is Mopar specific and not Chevy.
Don't be the exception.
Re: 833 Transmission id-numbers [Re: hemidart1] #1406085
03/21/13 10:33 PM
03/21/13 10:33 PM
JohnRR Offline
JohnRR  Offline
Are you looking for an overdrive trans because that is what that one is as pointed out by rapidfire.
That APPEARS to be a chrysler input shaft , if it's a trans you want to buy I would get a pilot bushing and bring it with you when you go to the transmission and make sure it fits properly.
Re: 833 Transmission id-numbers [Re: JohnRR] #1406086
03/22/13 12:10 AM
03/22/13 12:10 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
The GM A833's use a 10 spline input and the cases are GM specific. It doesn't even look like a mopar trans except the side cover. The trans in questions is mopar.
Re: 833 Transmission id-numbers [Re: Dan Brewer] #1406087
03/22/13 07:59 AM
03/22/13 07:59 AM
I was looking for a regular 833 so I am glad I posted the pics.
Thanks for helping me out on this!
1967 Hemi GTX
1969 Chrysler 300
Re: 833 Transmission id-numbers [Re: hemidart1] #1406088
03/22/13 09:21 PM
03/22/13 09:21 PM
MoPar Offline
MoPar  Offline
Looking at the picture with the shifter near by, appears to be a 6353 shifter with the grease fitting, my best guess would be a overdrive truck/van trans.
