Race harmonic balancer ? #1405655
03/20/13 09:59 PM
03/20/13 09:59 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I was looking at the ATI balancers on the Summit web sight and I narrowed it down to 3 balancers.One was steel and the other 2 were aluminum.That was the only difference.The 2 aluminum ones are described the same but they are different prices.
It will go on a 340 with a 3.79 stroke crank,internal balance pump gas motor. Which one do I need
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Race harmonic balancer ? [Re: D-50] #1405656
03/21/13 01:38 AM
03/21/13 01:38 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
personally i would run the steel one 2¢
Re: Race harmonic balancer ? [Re: D-50] #1405657
03/21/13 01:51 AM
03/21/13 01:51 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Race harmonic balancer ? [Re: jamesc] #1405658
03/21/13 03:32 AM
03/21/13 03:32 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
MB
Re: Race harmonic balancer ? [Re: D-50] #1405659
03/21/13 08:31 AM
03/21/13 08:31 AM
Niles, Michigan
Hitman340 Offline
Hitman340  Offline
Niles, Michigan
Call there teck line and they will help you get the right one.
Re: Race harmonic balancer ? [Re: HPMike] #1405660
03/22/13 10:33 PM
03/22/13 10:33 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I guess from the replys I got I need to order the steel one. Thanks....
