Hemi Spark plug tube upper O ring dimensions #1404540
03/18/13 07:50 PM
03/18/13 07:50 PM
closer to Canadian beer!
torkrules Offline OP
I'm neurotic
I'm neurotic
Anybody have the proper dimensions, Parker (or equivalent) part number, etc for the upper spark plug tube O-rings?
I could go out and pull one, but if someone has it and can let me know I would appreciate it.
I find the MP O-rings to be too big. John Arruzza states on his web site that he has the proper dimension o rings but there is no ability to buy them on the web site and there is no answer at his shop.
Thanks!
Re: Hemi Spark plug tube upper O ring dimensions [Re: torkrules] #1404541
03/18/13 08:43 PM
03/18/13 08:43 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
home of the
Sox and Martin Hemi Duster
Re: Hemi Spark plug tube upper O ring dimensions [Re: HEMIFRED] #1404542
03/18/13 09:13 PM
03/18/13 09:13 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Arruzza's are the only ones that fit. Best I can measure they look like about 1-1/4" id and .180 in diameter. I know what you are thinking. Why does Mopar sell us the wrong o-rings? Well, I'm not smart enough to answer that. John Arruzza's new phone number is 919-918-7584.
2011 Drag Pak Challenger
Re: Hemi Spark plug tube upper O ring dimensions [Re: rickseeman] #1404543
03/18/13 09:26 PM
03/18/13 09:26 PM
I'm neurotic
I'm neurotic
Thank you gentlemen. I'll try the new number. So they must be some odd ball size if John's are the only ones that seem to fit.
Yeah it's funny how the original manufacturer cant get the size right. They've been like this for years. You'd think someone would take notice.
Re: Hemi Spark plug tube upper O ring dimensions [Re: torkrules] #1404544
03/18/13 09:30 PM
03/18/13 09:30 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
If........don't even get me started on those people.
Re: Hemi Spark plug tube upper O ring dimensions [Re: rickseeman] #1404545
03/18/13 10:21 PM
03/18/13 10:21 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Bring the tube with you to your local auto parts store, and ask them to look in the back where they keep all of their loose O-rings. That's how I found mine.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Hemi Spark plug tube upper O ring dimensions [Re: DusterDave] #1404546
03/18/13 10:44 PM
03/18/13 10:44 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I tried old slant six o-rings and seem to fit ok. Never had any original hemi ones so I can't compare, ones i have are over weight.
Re: Hemi Spark plug tube upper O ring dimensions [Re: rickseeman] #1404547
03/19/13 09:11 AM
03/19/13 09:11 AM
I'm neurotic
I'm neurotic
No, No....don't get me started!
Re: Hemi Spark plug tube upper O ring dimensions [Re: torkrules] #1404548
03/20/13 07:13 AM
03/20/13 07:13 AM
pa
572charger Offline
572charger  Offline
pa
u talkin ones in the heads or in the valve cover ? i get mine for the heads at advance auto i think ended up being a metric part # i matched them up or call ray barton they have them
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Hemi Spark plug tube upper O ring dimensions [Re: 572charger] #1404549
03/20/13 09:58 PM
03/20/13 09:58 PM
I'm neurotic
I'm neurotic
ones in the valve cover. I talked to a local bearing supplier and ordered a couple of viton o rings of a couple of different sizes. We'll see how that works out
Re: Hemi Spark plug tube upper O ring dimensions [Re: torkrules] #1404550
03/21/13 01:37 AM
03/21/13 01:37 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I went through the same O-ring deal with my hemi restoration because of leaks around the spark plug wire boots at the factory valve cover. I brought a tube into a specialty gasket/O-ring supply place. The guy was really helpful and gave me several ones to test out and found that if I used a #318 sized ring that it makes a good tight fit around the tube and a firm fit into the valve cover - You have to install it on the tube first then firmly push it into the valve cover. It is a bit snug getting it out but not that bad considering I have no more leaks. I do not know the specs of the O-ring that Arruzza sells. I also came across a metric sized one that fits really good as well. If you go the Arruzza route please let us know what size they are using. O-rings at the local supply house were about 45 cents each. At that price I put new ones in every time I pull a tube.
Good Luck
Re: Hemi Spark plug tube upper O ring dimensions [Re: 68jim] #1404551
03/21/13 01:47 AM
03/21/13 01:47 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Link to an older thread
O-ring thread
Hope this helps.
