E-Body Challenger "Reverse Light" Grommet Hole? #1404472
03/18/13 05:24 PM
03/18/13 05:24 PM
California, USA
filmsurgeon Offline OP
California, USA
E-Body/Challenger/'Cuda: Can anyone tell me what the size of the hole should be for the "Reverse Light" grommet (firewall location between the booster/master cylinder/brake assembly, and the upper-right bulkhead connector hole)? Thanks.
Re: E-Body Challenger "Reverse Light" Grommet Hole? [Re: filmsurgeon] #1404473
03/18/13 08:06 PM
03/18/13 08:06 PM
buffalo, new york
0
00snake530 Offline
00snake530  Offline
buffalo, new york
i can measure in the morning if no response by then
70 Challenger r/t 4 speed
00 Viper gts
67 satellite pro street
03 Ferrari 360 spider
50 chevy fleetline deluxe
15 Escalade (daily)
Re: E-Body Challenger "Reverse Light" Grommet Hole? [Re: 00snake530] #1404474
03/19/13 04:07 AM
03/19/13 04:07 AM
California, USA
California, USA
I bought the harness from Evans Wiring. It has the grommet attached. I figured I could measure with a digital caliper. I thought maybe asking here would confirm the grommet size. The diameter measurement I got is 0.750" (the part of the grommet that would mate with the hole). So, I guess I'll drill a 3/4" hole. Thanks for the feedback.
Re: E-Body Challenger "Reverse Light" Grommet Hole? [Re: filmsurgeon] #1404475
03/19/13 12:03 PM
03/19/13 12:03 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
You are correct on the 3/4 in hole for 1970, assembly shown on left.
1971 shown on right used the larger 1 inch hole.
Re: E-Body Challenger "Reverse Light" Grommet Hole? [Re: mccannix] #1404476
03/19/13 02:27 PM
03/19/13 02:27 PM
California, USA
California, USA
Thanks for the confirmation.
Re: E-Body Challenger "Reverse Light" Grommet Hole? [Re: filmsurgeon] #1404477
04/20/13 09:37 PM
04/20/13 09:37 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Im adding a reverse light on my 70 cuda now that i converted to a 4 spd.
I cant seem to find where the light wire goes. At least not on my wiring diagrams.
So reading your post it goes through the firewalll to the engine compartment ? Were does it go from there?
Sorry for the post hijack
Re: E-Body Challenger "Reverse Light" Grommet Hole? [Re: Finoke] #1404478
04/21/13 04:15 PM
04/21/13 04:15 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
Here's another pic of an e body firewall. I got it from moparts and saved it.
Re: E-Body Challenger "Reverse Light" Grommet Hole? [Re: Finoke] #1404479
04/21/13 04:27 PM
04/21/13 04:27 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
The harness from the trans switch plugs into the bulkhead connector right below where your wiper motor plugs in. A pigtail wire comes out of that connector and plugs into the one from your dash light. That comes through the firewall with the heavy black grommet as pictured in the other replies.
Re: E-Body Challenger "Reverse Light" Grommet Hole? [Re: HEMIDOG 70] #1404480
04/21/13 05:19 PM
04/21/13 05:19 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
thanks Hemidog! Excellent!
Re: E-Body Challenger "Reverse Light" Grommet Hole? [Re: Finoke] #1404481
04/21/13 08:28 PM
04/21/13 08:28 PM
Fremont, CA.
Topcat Offline
Topcat  Offline
Fremont, CA.
71's the grommet is located below the gas pedal from what I heard.
Re: E-Body Challenger "Reverse Light" Grommet Hole? [Re: filmsurgeon] #1404482
04/23/13 09:15 AM
04/23/13 09:15 AM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
Thanks for the detail pics.
