Re: 2002 Ram 1500 a/c question
[Re: 74Charger]
#1404344
03/18/13 01:14 PM
03/18/13 01:14 PM
Challenger 1
Cincinnati, Ohio
Possibly a blower motor resistor that reduces the current to motor on the lower speeds? At least that is the way manufacurers used to do it.
For sure, this is what they look like for chevy.
They are located in the heater box somewhere.
Don't fret about replacing the blower motor, it needed it anyway because more than likely the old one was starting to draw too much amps and burned out the speed resister and the new one(resister) would have got cooked by the old blower motor sooner than later.
And then you would have thought you got a bad blower resister.
[Re: Challenger 1]
#1404347
03/18/13 01:38 PM
03/18/13 01:38 PM
Posts: 1,173 Central Louisiana
jim
Central Louisiana
So this bad resisiter in on the climate control module in the dash or somewhere in the blower / duct box? My work internet is blocking photobucket pictures. Can't see anything but a red 'X' until I get home this evening.
[Re: Challenger 1]
#1404349
03/18/13 02:56 PM
03/18/13 02:56 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Should be on the pass side by the blower motor you will have to lay on the flor and look up at it.The new ones dont look like that pic.They are now all small modules.It will have at least 2 big wires usually black and red.They have power all the time and the computer controls a ground to them.Last one I did at the shop was about 20 bucks shop cost.Its nothing new for them to go bad.Usually the motor is good.GM was famous for them going bad.Typically has 2 small bolts hold it in some have 3.Rocky
Chrysler Firepower
[Re: Challenger 1]
#1404352
03/28/13 10:11 PM
03/28/13 10:11 PM
jim
Central Louisiana
I got up under the dash today and the only thing I found was this thing. Looks like a ballast resistor but nothing like what was posted above. It has a burnt look to one corner and a flat wire that looks like it should be connected like a fusible link, the white part is like ceramic. Is this it????? There were leaves and dirt all packed around it. I got them cleaned out and the fan ran on high to blow trash and gunk out of the mounting hole and all over the floor of the truck. Are we on the right track replacing this little jewel? Sorry for the crappy pictures, all I have with me is the phone camera. Jim H.
