Re: cheetah shifter and t brake button.
[Re: mopar dave]
#1404305
03/18/13 02:06 PM
03/18/13 02:06 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
ok,i'll try the botton on the shifter first. manually shifted,do you think the cheetah is any quicker than the promatic?
Yes, it is quicker. As has been stated,, you will be in high gear before you know it. I have the Cheetah in my car. If I had to do it over, I would use the Hurst Quarter Stick like I always used before. I finally got used to the Cheetah by not 'pulling' on it. I just slap/smack the handle when it's gear change time.
If you like drag racing, support your local track.
[Re: mopar dave]
#1404311
03/19/13 12:24 AM
03/19/13 12:24 AM
Posts: 43,255 Bend,OR USA
Cab_Burge
