01 Ram serpantine belt?? #1404196
03/18/13 03:15 AM
03/18/13 03:15 AM
Iowa
76dodgeboy Offline OP
Iowa
The wife 01 needs an act compressor. Can I get a non ac belt and by pass the compressor? I haven't looked at the diagram on the truck. It was dark
Re: 01 Ram serpantine belt?? [Re: 76dodgeboy] #1404197
03/18/13 07:41 AM
03/18/13 07:41 AM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
I know four season has a replacement pulley setup to replace the compressor and you can use your old belt... not sure if a non-ac belt would work without rubbing on something... then all cars are different...
Re: 01 Ram serpantine belt?? [Re: BigTerry] #1404198
03/18/13 08:54 AM
03/18/13 08:54 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
is this a 5.2/5.9? or 4.7? I don't remember when they ditched the 5.2
if you have a 4.7 I can't help, because I have no clue.
if you have a 5.9, then yes, you can "short belt" it and bypass the AC. however, it's not as simple as just buying a non-AC belt. For some reason, dodge changed the position of the idle pulley between the AC and non-AC brackets, and the factory non-AC belt won't work, but there is a belt that does work (I just don't remember the length off the top of my head)
**Photobucket sucks**
Re: 01 Ram serpantine belt?? [Re: 70Cuda383] #1404199
03/18/13 12:12 PM
03/18/13 12:12 PM
Iowa
Iowa
The diagrams Im finding show the belt just by passes the compressor
Re: 01 Ram serpantine belt?? [Re: 76dodgeboy] #1404200
03/18/13 12:13 PM
03/18/13 12:13 PM
Iowa
Iowa
Re: 01 Ram serpantine belt?? [Re: 76dodgeboy] #1404201
03/18/13 12:17 PM
03/18/13 12:17 PM
Iowa
Iowa
Not looking to spend a bunch of money. Ac will be fixed just HAVE to have the truck drivable as its the wifes daily driver. We dont have the money for a new compressor rite now
Re: 01 Ram serpantine belt?? [Re: 76dodgeboy] #1404202
03/18/13 01:53 PM
03/18/13 01:53 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Yes, it just bypasses the A/C pulley, but trust me on this, you cannot take a non-AC belt, and put it on an engine with the A/C bracket, and expect it to work, because the location of the idle pulley between the alternator and the A/C pump is ever so slightly different between the 2 trucks, and it will not work unless you remove the Alternator/AC bracket, and replace it with the factory non-AC alternator bracket.
there IS a belt that will do what you want, but it is NOT the factory non-AC belt that the parts monkeys will look up by year/make/model/engine in their computer.
Re: 01 Ram serpantine belt?? [Re: 70Cuda383] #1404203
03/18/13 01:56 PM
03/18/13 01:56 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
http://www.dakota-durango.com/forum/showthread.php?t=120283
looks like if you go to autozone, an 884k7 will work.
Re: 01 Ram serpantine belt?? [Re: 70Cuda383] #1404204
03/18/13 02:43 PM
03/18/13 02:43 PM
Truckville, the capital of NY
85_Ram_4speed Offline
I used a Dayco 5060900 belt and bypassed the A/C. It is one rib short so you have to make sure all the pullies have the same rib exposed. This is what my local Advanced Auto had in stock when I needed it, thus why its 6 rib instead of the normal chrysler 7.
Buying a normal Non A/C belt is WAAYY to short. Also, getting a belt that will put the tensioner in the middle of its travel is also important.
Outcast Dodge guy.
Re: 01 Ram serpantine belt?? [Re: 70Cuda383] #1404205
03/18/13 10:43 PM
03/18/13 10:43 PM
Iowa
Iowa
Gay at advance cross referenced it and it come up the same as 885k7 witch is non ac
Ended up with the one
Re: 01 Ram serpantine belt?? [Re: 76dodgeboy] #1404206
03/19/13 12:47 PM
03/19/13 12:47 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
so the 884K7 was the factory non-AC length belt?
sorry. I couldn't remember the right belt off the top of my head, and that guy posted "884k7 works" I thought he meant that was the right belt for bypassing the AC compressor.
Re: 01 Ram serpantine belt?? [Re: 70Cuda383] #1404207
03/19/13 02:02 PM
03/19/13 02:02 PM
Iowa
Iowa
The non ac belt through advance was 885k7 but when he cross referenced the 884k7 from autozone it came back to 885k7. The pic I posted is what we are using.
Re: 01 Ram serpantine belt?? [Re: 76dodgeboy] #1404208
03/19/13 02:05 PM
03/19/13 02:05 PM
Iowa
Iowa
Wasn't a big deal. Itsunami all trial and error. I debt thing the guys at our auto zone would have been as helpful as advance
Re: 01 Ram serpantine belt?? [Re: 76dodgeboy] #1404209
03/20/13 09:58 AM
03/20/13 09:58 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I've noticed the same thing. Auto Zone will hire any breathing monkey that walks in the door looking for a job, and when you ask for "serpentine belt 885k7" they need you to tell them year, make model so the computer can tell them what isle and shelf it is on...when I'm standing at the counter I can see the belts hanging on the rack behind them.
the guys at my local advance auto seem to be a little bit more knowledgeable about car parts and finding stuff...but still, just ever so slightly.
Re: 01 Ram serpantine belt?? [Re: 76dodgeboy] #1404210
03/21/13 09:22 PM
03/21/13 09:22 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
