Oil Filled Shocks!
#1404009
03/17/13 09:47 PM
03/17/13 09:47 PM
Posts: 2,525 Louisville, KY
E-Ticket
Louisville, KY
Anyone have any or know where I can buy a pair of rear "oil" filled shocks?? I am looking for the least expensive type brand, loosest traveling, no frills, oil filled long shock that would be the correct length for the rear of a 69 or 70 C-body car?? E-mail - Challengers1970@aol.comThanks in advance!!!
Re: Oil Filled Shocks!
[Re: A12]
#1404014
03/18/13 01:58 PM
03/18/13 01:58 PM
Posts: 75,095 A Banana Republic near you.
JohnRR
About $27 bucks each including shipping I think?
Don't know if you can do any better on a new shock.....maybe there's a used set out there
From the auction
You are purchasing 1 pair (two pieces) of new Gabriel gas charged shock absorbers.
[Re: JohnRR]
#1404016
03/18/13 02:55 PM
03/18/13 02:55 PM
Posts: 21,546 N.E. OHIO, USA
A12
N.E. OHIO, USA
From the auction
I figured at $40 bucks for the pair and $15 for the shipping that's about............
[Re: A12]
#1404017
03/18/13 05:13 PM
03/18/13 05:13 PM
JohnRR
From the auction
I posted that because he does not want GAS shocks .
[Re: A12]
#1404019
03/18/13 05:31 PM
03/18/13 05:31 PM
JohnRR
I think the only non-gas charged shocks you might find are the old Koni's for around $125 each
I didn't come across those in my google search , but hiltopap has 2 pairs of the a/c delcos I linked above ...
[Re: E-Ticket]
#1404023
03/18/13 11:33 PM
03/18/13 11:33 PM
A12
N.E. OHIO, USA
http://www.koni-na.com/classic.cfm
Thanks!!! Man.....whatever happened to the common....good ole, USA made, ordinary, inexpensive replacement parts?? Seems like they are getting tougher to find.....
I was just in an O'Reily's auto parts store and saw the entire line up of Monroe shocks and the bottom shock the Monroe-Matic-Plus looks like an air/oil shock so I asked the you kid who was processing my purchase if that's what they were?
I was floored when the young kid said "I don't know, do they make such a thing" I said can you ask someone else? "Naw they wouldn't know either" I got so pis...miffed that I walked out and for got my credit card and had to go back and get it
I'll check out the Monroe Matic's and see what they are and how much they are too.
[Re: jlatessa]
#1404026
03/19/13 10:16 AM
03/19/13 10:16 AM
A12
N.E. OHIO, USA
Don't all shocks have oil movement through valving or orifices, gas charged or not??
I thought the gas charging was an added feature for whatever purpose...maybe sales hype??
Joe
Nitrogen charged shocks are a feature as the nitrogen is more stable in high heat applications and the gas pressure (usually 100+ psi) helps keep the shock fluid from "cavitating" when the shaft/piston moves very quickly like when hitting a pothole a speed. A shock with a gas/oil separator (Dr. De Carbon type) is even better because it keeps the gas/air from emulsifying or aerating reducing the damping.
