J-B Weld or J-B Marine Weld or other brand Marine epoxy #1403872
03/17/13 08:05 PM
03/17/13 08:05 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Normally I use J-B Weld epoxy but some older guys swear there is a "Marine Epoxy" that is way stronger and better than any other epoxy. I've used Devcon, Permatex, etc., and see there are a number of marine brand epoxies available just don't know which one they are talking about? They say it's much stronger than any J-B procuct even the J-B Marine Weld.
Would anyone happened to know what Marine Epoxy is the strongest available........trying to fix a magnesium cover that has a water pump in it. TIA.
Re: J-B Weld or J-B Marine Weld or other brand Marine epoxy [Re: A12] #1403873
03/17/13 08:36 PM
03/17/13 08:36 PM
IN
ahy Offline
ahy  Offline
IN
If you are really concerned about strength, how about welding? A good weld shop can weld magnesium.
Re: J-B Weld or J-B Marine Weld or other brand Marine epoxy [Re: A12] #1403874
03/17/13 08:48 PM
03/17/13 08:48 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Devcon is a very good epoxy. Z-spar and splashzone are the ones you are thinking of. Both are the same epoxy.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: J-B Weld or J-B Marine Weld or other brand Marine epoxy [Re: pittsburghracer] #1403875
03/17/13 08:51 PM
03/17/13 08:51 PM
PA.
"Little"John
"Little"John
PA.
I've heard that the epoxy that Goodson sell is z-spar in a smaller amount.
http://www.westmarine.com/webapp/wcs/sto...56#.UUZWwFfS9_M
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: J-B Weld or J-B Marine Weld or other brand Marine epoxy [Re: pittsburghracer] #1403876
03/17/13 08:57 PM
03/17/13 08:57 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
ive always used MARINE-TEX.i patched a crack on the inside of my float bowl on my 57 harley and it worked for 5 years till i sold it.
Re: J-B Weld or J-B Marine Weld or other brand Marine epoxy [Re: pittsburghracer] #1403877
03/17/13 09:00 PM
03/17/13 09:00 PM
PA.
"Little"John
"Little"John
PA.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: J-B Weld or J-B Marine Weld or other brand Marine epoxy [Re: A12] #1403878
03/17/13 09:14 PM
03/17/13 09:14 PM
NASHVILLE
MAVERICKSHEMI Offline
NASHVILLE
The epoxy that DOT uses to glue the reflectors into the road surface is some very strong stuff. I had some, never failed....
Re: J-B Weld or J-B Marine Weld or other brand Marine epoxy [Re: bonefish] #1403879
03/17/13 09:57 PM
03/17/13 09:57 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I was going to say Marine-Tex also. I used it to seal a leaking sending unit on my '69 Dart. Never leaked again after that.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: J-B Weld or J-B Marine Weld or other brand Marine epoxy [Re: bonefish] #1403880
03/17/13 10:41 PM
03/17/13 10:41 PM
nj
N
notforsale440 Offline
N
nj
ding ding ding......we have a winner......marine-tex, "the mighty repair kit"......its expensive, but........ I use it over welded patches, under body filler; great for fiberglass repairs, too; among several other uses.......and its waterproof
Re: J-B Weld or J-B Marine Weld or other brand Marine epoxy [Re: bonefish] #1403881
03/18/13 03:04 AM
03/18/13 03:04 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Yep as also stated after your post I think that's the stuff that all the hot rod and "old guy" talk about as being "THE stuff". I'll see if I can find it here locally......live near Lake Erie so lots of boat supply places
Re: J-B Weld or J-B Marine Weld or other brand Marine epoxy [Re: notforsale440] #1403882
03/18/13 03:06 AM
03/18/13 03:06 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Yep that sounds like the stuff, see my post before this
Re: J-B Weld or J-B Marine Weld or other brand Marine epoxy [Re: pittsburghracer] #1403883
03/18/13 03:10 AM
03/18/13 03:10 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
http://www.goodson.com/search.php?mode=search&page=1
John thanks for the link. I've purchased a lot of things for our (motorcycle) race shop(s) from Goodson and have an account with them and have been looking (elsewhere) for the porting epoxy, thanks again for that reminder/link
http://www.goodson.com/Port-Reshaping_Kit/
Re: J-B Weld or J-B Marine Weld or other brand Marine epoxy [Re: ahy] #1403884
03/18/13 03:15 AM
03/18/13 03:15 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Andrew, I thought about that but I'd have to do a lot of machining and grinding as it is a magnesium motorcycle clutch cover and water pump with a waterpump seal. It's just eroded and the pits just need filled and smoothed out. I'm afraid the cover will warp at the engine seal/gasket and the water pump cover and possibly where the crankshaft/water pump seal is. Thanks though for the suggestion.
Re: J-B Weld or J-B Marine Weld or other brand Marine epoxy [Re: notforsale440] #1403885
03/18/13 06:40 AM
03/18/13 06:40 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I used it to seal a gas tank, good stuff.
Re: J-B Weld or J-B Marine Weld or other brand Marine epoxy [Re: gdonovan] #1403886
03/18/13 06:02 PM
03/18/13 06:02 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I remember back in 77, i had a crankcase issue on a KTM 400. Tried to get it welded but the weld wouldn't take. I Managed to pick another one up in the end. As i recall, it had a lot of impurities in the magnesium.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: J-B Weld or J-B Marine Weld or other brand Marine epoxy [Re: deaks] #1403887
03/18/13 07:29 PM
03/18/13 07:29 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Mick
Doing an '84 KTM 250 MX water cooled bike right now..and want to use the best epoxy out there, heard of the "marine" epoxy being the stuff to use. Hope to do some vintage racing this summer
Re: J-B Weld or J-B Marine Weld or other brand Marine epoxy [Re: deaks] #1403888
03/18/13 07:41 PM
03/18/13 07:41 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Mick
Those bikes were so light back then with magnesium engine cases, mag clutch cover, aluminum head and cylinder and then the Mahle Nicasil plating and no cast iron liner........
I think I'm headed to the auto parts to get the standard J-B Weld and the J-B Marine and do a comparison by epoxying two parts to each other with each type of epoxy and see which holds and which one breaks loose
Re: J-B Weld or J-B Marine Weld or other brand Marine epoxy [Re: A12] #1403889
03/19/13 12:24 AM
03/19/13 12:24 AM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
Hi Temp Lab Metal
http://www.alvinproducts.com/Products/Products.asp?id=2
Be advised product needs to final cure at 425* for 1 hr
