Let's talk small block a body headers... #1403539
03/17/13 03:46 AM
03/17/13 03:46 AM
Between a rock & a hard place
cudadoug Offline OP
cudadoug  Offline OP
Are the any race headers out there for this application that are multi piece slip fits....ala a 383/440 b/e body race header?? Tired of fighting the 1 3/4" one piece Hookers.
Our RHS heads are drilled for 2 bolt patterns....the one we're not using looks like W2 headers will bolt up.
Help...
Thanks in advance!
Re: Let's talk small block a body headers... [Re: cudadoug] #1403540
03/17/13 04:00 AM
03/17/13 04:00 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: Let's talk small block a body headers... [Re: 70AARcuda] #1403541
03/17/13 04:03 AM
03/17/13 04:03 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
Re: Let's talk small block a body headers... [Re: cudadoug] #1403542
03/17/13 10:34 AM
03/17/13 10:34 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
These are multi piece and go on great. I have the 1 7/8" with 3 1/2" slip fit collectors on my Dart.
http://www.hedmanhusler.com/MOPAR-Street-and-Strip-Headers
Re: Let's talk small block a body headers... [Re: justinp61] #1403543
03/17/13 11:11 AM
03/17/13 11:11 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
I had the 1 7/8" Hedman Hustlers on my 73 340 Dart sport and loved them. Only had to cut 1 fairly small hole on each inner fender for the pipes to run through. Lots of room for the starter, shifter cable, oil filter, and no burned #5&7 plug wires. Good ground clearance too.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Let's talk small block a body headers... [Re: 71yelladustr] #1403544
03/18/13 12:13 AM
03/18/13 12:13 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
do you have a part # for those?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Let's talk small block a body headers... [Re: Stroker Scamp] #1403545
03/18/13 09:56 AM
03/18/13 09:56 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'm pretty sure 75140 is the number for a standard port, 1 7/8 tube and 3 1/2" slip fit collector. What oil pan do you have?
Re: Let's talk small block a body headers... [Re: cudadoug] #1403546
03/18/13 10:24 AM
03/18/13 10:24 AM
Locomotion Offline
Locomotion  Offline
Have you considered TTI 1 5/8"-1 3/4" step?
I have them on RHS/LA-X heads and they work great. The initial 1 5/8" section is not a restriction in most applications. In fact, some custom race combos start out at 1 1/2" and step up 2 more times. As you've probably read, the fit is excellent and they fit the 8 qt. Milodon pans. Most other headers don't.
Another thing to consider is that NHRA has come out with a new rule for multi-piece headers for 2014. Something about having to use an approved teather for the attached pieces. Not sure how far back in the classes that applies to off hand.
Re: Let's talk small block a body headers... [Re: Locomotion] #1403547
03/19/13 02:56 AM
03/19/13 02:56 AM
cudadoug Offline OP
cudadoug  Offline OP
YIKES! A $200+ diff for the Hedman 1 3/4 vs. the 1 7/8. Seriously Hedman??
Myron I am consdiering TTI's, but I've heard they are a pain as well. Our 1 3/4 Hookers, hit EVERYTHING when trying to get them off. The Trans dip stick, the shock towers, the steering column. AND tubes 1,3 2 and 4 are RIGHT up against the oil pan, even after I massaged it (think ball peen) for clearance.
If we could get the TTI's on without jacking up the motor (thus having to remove the Trans shield) and trans dip stick, I'd probably go that way. I like the take apart design of the Hedmans, but the NHRA collector tether deal S U C K S !!!
Re: Let's talk small block a body headers... [Re: cudadoug] #1403548
03/19/13 04:29 AM
03/19/13 04:29 AM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
If I'm reading the new rule correctly, the hedmans I have don't need the tether. The rule states: Exhaust,collectors,stacks must be securely fastened (i.e.,metal straps,bolted,welded ect) Here is a pic of my W2 1 7/8" to 2" Hedman Hustlers with a 3 1/2" collector which I believe are made exactly the same as the headers you are interested in. Notice the bolt straps on the collectors and every tube that comes apart. The only other problem I could think of is these headers don't work with an oil pan with a bottom kick out. I have a straight sided Stef's oil pan.
Re: Let's talk small block a body headers... [Re: b1dartsport] #1403549
03/19/13 04:51 AM
03/19/13 04:51 AM
b1dartsport Offline
b1dartsport  Offline
Here is a pic of the pan I am going to use with the Hedmans.
Re: Let's talk small block a body headers... [Re: b1dartsport] #1403550
03/19/13 06:32 AM
03/19/13 06:32 AM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
1 3/4 Hookers with slip on collectors will practically fall right in................
Re: Let's talk small block a body headers... [Re: 10.90 Racer] #1403551
03/19/13 09:37 AM
03/19/13 09:37 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
B1dartsport, my 1 7/8" Heddmans are the same as yours, they have tabs for bolts. I run a Milodon pan with mine but had to section it to clear the headers. It was a little work but my pan doesn't hang down where I'll knock it off.
Re: Let's talk small block a body headers... [Re: cudadoug] #1403552
03/19/13 12:42 PM
03/19/13 12:42 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
How about the hooker 1 3/4" "street" header ? Uses a slip on pipe for cylinders 1 and 2, manual steering only. One piece collector. 5204's
Re: Let's talk small block a body headers... [Re: 70AARcuda] #1403553
03/19/13 12:48 PM
03/19/13 12:48 PM
Renton Washington
Triple Threat Offline
Renton Washington
I have 2" x 3.5" Hooker super comps, rear tube on each side goes through the inner fender.
They are a serious pain in the ...
I don't recommend them. My next set will either be hedmans, or custom.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Let's talk small block a body headers... [Re: justinp61] #1403554
03/19/13 01:41 PM
03/19/13 01:41 PM
b1dartsport Offline
b1dartsport  Offline
I ran that Stef's pan before,it is not as deep as it looks in the picture. It only holds 7 qts with the filter. I run it with a 3 qt accusump. 7,500 rpm and scraped the rear bumper on the ground a couple of times and no damage.
Re: Let's talk small block a body headers... [Re: b1dartsport] #1403555
03/19/13 01:51 PM
03/19/13 01:51 PM
cudadoug Offline OP
cudadoug  Offline OP
You are right...they must be secured with a bolt, welded, etc. But as it is written, seems to me that any collector that is removeable (bolted on) will need the tether next year:
Effective Jan. 1, 2014, removable multi-piece exhaust collectors/stacks must be
securely fastened with an NHRA accepted header tether, such as Lokar’s
1400009 or 1401009 to prevent loss of collector/stacks during competition.
I Shouldn't have said S U C K S !!! I'm all for safety but it's just one more thing we have to deal with, rather than have tech guys TECH the cars. But it does effect my decision about what headers to buy. If it's going to add...say $100 to our header cost AND be one more thing to bolt on/unbolt when working on the car...Hedman's aren't looking as good as the TTI. Or as Dustin said...maybe even custom.
On a related note, our pan is the Milodon 10qt SS pan (drag link tube). No kick outs, but the routing of the Hookers (tubes 3,5,2,4) ran into both pan sides. Just looking at the Headman's though...they have to way way more user friendly than what we have now.
What to do...what to do...
Re: Let's talk small block a body headers... [Re: cudadoug] #1403556
03/19/13 02:32 PM
03/19/13 02:32 PM
b1dartsport Offline
b1dartsport  Offline
Another thing to think of is everyone that I know of who has switched from the 1 7/8" TTIs to the Hedmans has picked up,some as much as 2 tenths. I think that is due to the fact that the TTIs have a 3" collector vs 3 1/2" for the Hedmans and the Hedmans are better designed as a race header. I ran the TTIs on my last combo.
Re: Let's talk small block a body headers... [Re: b1dartsport] #3060303
07/18/22 06:18 PM
07/18/22 06:18 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Just drug up this old thread, hoping to see how big the hole is for the 75140 1 7/8 Headman race header.
Btw..to the above poster. I swapped from 3 inch to 3.5 inch collector on a 9 sec W5 car I had, saw absolutely nothing on a time slip.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
