Dana 60 ? Power lok vs. Trac lok #140299
10/23/08 01:33 AM
10/23/08 01:33 AM
Renton Washington
Triple Threat Offline OP
Renton Washington
I am looking at buying a Dana 60 out of a 1965 ford truck to use as the basis of a rearend I am building to replace the 8 3/4 in my car.
My question Is would this rearend likely have a power lok as it is an early pre 1969 rearend, or did danas not change with the years like our 8 3/4's did? Is their an easy way to identify what style of posi is in this beast? Also I understand that the power lok is a clutch type "posi" unit. Does this mean the trac lok is a cone style unit?
I've briefly searched google and the tech archives here and I can't seem to find all the answers I am looking for so I am turning to you guys.
Thanks in advance,
Dustin
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Dana 60 ? Power lok vs. Trac lok [Re: Triple Threat] #140300
10/23/08 01:48 AM
10/23/08 01:48 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
yes the Power Loc is a clutch unit. It is the best between the 2. the drawback is the Fords used 16 spline axles. The Dodge one I had used 30 spline axles. The new spiders are around 150 to 200 a pair I hear.. check your measurements, sometimes a truck rear isnt wide enough when you cut the truck ends off.. good luck
I am truckless..
Re: Dana 60 ? Power lok vs. Trac lok [Re: Triple Threat] #140301
10/23/08 01:49 AM
10/23/08 01:49 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
The Power Lock differential bolts together with small windows where you can see the spider gears. The Track lock is a one piece machined casting with big windows that you load the clutches through. I have one of each in my Kirkland garage, the Track Lock is worn-out and the Power Lock is supposedly fresh. The Power Lock is the stronger case of the two, they are both for the 3.54 to 4.10 gears and 30 spline axles. The Ford Dana should have 14 or 16 spline axles, weaker than higher spline count units, but that should be one of the first things you change anyway.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Dana 60 ? Power lok vs. Trac lok [Re: Triple Threat] #140302
10/23/08 08:27 AM
10/23/08 08:27 AM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Hopefully Doctor Diff will reply here, but also with the Dana clutch style units be careful because
one has much less axle engagement than the other.
Dana made 2 different internal gears. One is a split
and the other is solid. I can post pictures tonight
if you are interested.
Not too many guys on this post seem to know this.
The ones that do usually have stripped out their axles or do diffy work.
Re: Dana 60 ? Power lok vs. Trac lok [Re: Dart 340] #140303
10/23/08 09:43 AM
10/23/08 09:43 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
A '65 rear would originally have a power-lock.
Axle spline strippng is not as common in Dana 60 power-locks because the side gears are wider than the 8 3/4" versions.
New 35 spline internals with the upgaded (1 piece) side gear arrrangement are readily available.
Re: Dana 60 ? Power lok vs. Trac lok [Re: DoctorDiff] #140304
10/23/08 11:01 AM
10/23/08 11:01 AM
Renton Washington
Renton Washington
I imagine you sell these or can get them? Whats the ballpark price for everything to make the switch? You can E-mail or PM me here if you don't want to post the price. Moparboy@comcast.net
-Dustin
Re: Dana 60 ? Power lok vs. Trac lok [Re: Triple Threat] #140305
10/23/08 11:27 AM
10/23/08 11:27 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I stock the complete internal parts kit for $200.
Re: Dana 60 ? Power lok vs. Trac lok [Re: DoctorDiff] #140306
10/23/08 06:39 PM
10/23/08 06:39 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
Trac lok's are junk, 1 set of spiders, weak clutch pressure, I burnt a new set of clutchs out in one night.
MM
Re: Dana 60 ? Power lok vs. Trac lok [Re: DoctorDiff] #140307
10/23/08 09:03 PM
10/23/08 09:03 PM
Renton Washington
Renton Washington
Does that include clutches?
-Dustin
Re: Dana 60 ? Power lok vs. Trac lok [Re: Triple Threat] #140308
10/24/08 12:35 AM
10/24/08 12:35 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Yes, it includes all internal parts, plus a bottle of friction modifier additive.
Re: Dana 60 ? Power lok vs. Trac lok [Re: DoctorDiff] #140309
10/24/08 08:33 AM
10/24/08 08:33 AM
Renton Washington
Renton Washington
Thanks Cass, gotta go pick up that dana this weekend and then I will be in touch.
-Dustin
Re: Dana 60 ? Power lok vs. Trac lok [Re: Triple Threat] #140310
10/24/08 09:27 AM
10/24/08 09:27 AM
Detroit boy in Saugerties, NY
BrianShaughnessy Offline
Here's a page I found the other month detailing power vs trac. It's a .pdf deal.
http://jeepgarage.free.fr/OWN/differential%20dana%20trac%20lok%20and%20power%20lok.pdf
I ended up rebuilding my traclok with a kit from Cass. It was an adventure.
The next time I burn a set of clutches out it's gonna go on top of the pile.
Black Betty: '69 Charger RT: 440 6 pack, TKO600 5 speed, 3.73 Dana.
Sinnamon: '69 Charger RT: 440, 727, 4.30 8.75. High School Sweetheart.
El Grande: '98 Grand Cherokee 5.9 Limited.
Re: Dana 60 ? Power lok vs. Trac lok [Re: 500ciDuster] #140311
10/24/08 04:08 PM
10/24/08 04:08 PM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
MM
Thats why we call them trash-lock!
Re: Dana 60 ? Power lok vs. Trac lok [Re: 10sec440] #140312
10/24/08 09:00 PM
10/24/08 09:00 PM
Renton Washington
Renton Washington
This particular rearend is a semi floater, not a full floater as was originally thought. This still gonna be ok as a core? I am going to check it all out tomorrow afternoon.
Gonna check :
Date code on housing
Verify its a power lock not a "trash lock"
Big axle tube diameter
Anything else I should check or be aware of?
I really appreciate the help everyone has offered so far.
-Dustin
Re: Dana 60 ? Power lok vs. Trac lok [Re: Triple Threat] #140313
10/24/08 09:13 PM
10/24/08 09:13 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
IIRC the Trac loc wasnt around in those days.. Ford did use Detroit lockers also in those days as well as the Power Locks... good luck
I am truckless..
Re: Dana 60 ? Power lok vs. Trac lok [Re: 340SHORTY] #140314
10/24/08 10:09 PM
10/24/08 10:09 PM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
I thought most performance Mopars from the 60's to early 70's had the Trak Lok? Did all of those rearends just explode spontaneously because of it? I thought they were supposed to be pretty durable back in the day.
Re: Dana 60 ? Power lok vs. Trac lok [Re: Blakcharger440] #140315
10/24/08 10:44 PM
10/24/08 10:44 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
those units had the internal clutches like the power lock,,, not the externl styly like Trac locs. the D60s were refered to as Trac pack with 3.54s or super Track packs with 4.10s.
I am truckless..
