Relay wiring problem #1402934
03/15/13 08:57 PM
03/15/13 08:57 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
I am trying to wire in relays to my headlight system and have a problem that is stumping me.
With the relays wired in everything is fine with the lights off, fine with the park lights on, but when I switch on the headlights I get no headlights and my voltmeter drops from 15 volts to 10 volts with the engine running.
I have checked and rechecked the wiring and everything appears to be correct. The only thing I found which seems weird to me is that with the relays just sitting on the bench they have continuity between the coil ground (terminal 85) and the relay trigger coil feed (terminal 86). Is this normal?? Could I have 2 brand new relays that are both defective?
My knowledge of wiring is very basic, so ANY help or suggestions are appreciated!
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Relay wiring problem [Re: MadMatt] #1402935
03/15/13 09:13 PM
03/15/13 09:13 PM
I think you want the original wire to the headlights to go to the coil in (86) & the other end of that circuit (coil ground (85) to ground & the 2 other terminals one of them is connected to the headlights and the other one is connected to the power source (batt or alt) & when 86 is energized from the headlight switch & therefore groundes that circuit thru 85 that it connects the other 2 terminals (headlights/alt or batt) to each other. Someone will chime in with more detailed help
Re: Relay wiring problem [Re: RapidRobert] #1402936
03/15/13 09:39 PM
03/15/13 09:39 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
You can wire it like this, 85 is trigger, 86 ground, 30 power in, 87 power out.
85-86 is a chargeable field/solenoid, so it should have continuity.
Sounds like you have a short somewhere. Where are you pulling power for the #30 relay terminal?
I build headlight relay kits and use none of the old wiring, except to trigger the relays (minimal load)
Re: Relay wiring problem [Re: RobX4406] #1402937
03/15/13 10:58 PM
03/15/13 10:58 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
I am using the original headlight power wire for the trigger source. For power I am pulling from the battery positive terminal. Grounds are grounded to core support and read good continuity to engine block.
Re: Relay wiring problem [Re: MadMatt] #1402938
03/16/13 12:02 AM
03/16/13 12:02 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Do you have either high or low beams? You should be triggering the relays off the high and low beam feeds to the bulbs. Are you sure you have the out power from the correct relay terminal?
Re: Relay wiring problem [Re: stumpy] #1402939
03/16/13 01:03 AM
03/16/13 01:03 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
No high beams or low beams. And since the voltage drop happens I think it's clear that the relays are being triggered. I'm taking the power out to the headlights from terminal 87.
Re: Relay wiring problem [Re: MadMatt] #1402940
03/16/13 10:06 AM
03/16/13 10:06 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
This topic is perfect timing for me right now. I'm trying to do the same thing shortly. Where do you get these relays and where do most people mount them? I guess you wire the A/C compressor the same way?
Re: Relay wiring problem [Re: fastmark] #1402941
03/16/13 12:56 PM
03/16/13 12:56 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Any parts store will have the relays.
Re: Relay wiring problem [Re: MadMatt] #1402942
03/16/13 01:05 PM
03/16/13 01:05 PM
I'm assuming you have 1 relay for both hi/low beams. I'd think if the headlight power wire TO the dimmer switch is connected instead to 85 & 86 is permanently grounded and 30 is connected to the battery & 87 is connected to the upstream side of the dimmer switch where the headlight power in wire originally was connected to, that you'd be good. On a related note I would highly suggest powering "30" from the alt rather than the battery
Re: Relay wiring problem [Re: RapidRobert] #1402943
03/16/13 01:15 PM
03/16/13 01:15 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Actually, I have 1 relay for low beams and 1 for high beams. Each uses the respective original head lamp power wire as the trigger source. I'm pulling power from the battery terminal, but that is the same terminal the alternator is hooked to, so it should not make a difference.
Re: Relay wiring problem [Re: MadMatt] #1402944
03/16/13 01:33 PM
03/16/13 01:33 PM
Correct, no difference on the problem at hand. Well either both relays are bad (not impossible but unlikely) or it's not wired right & from your descrip it's good & it is a simple 4 wire system unless we're missing something & it sounds like we are. I'd start by checking both of the relays with your VOM & put fire to 86 & ground 85 (I may have 85/86 backwards & may not even make a difference) & see if that makes 30 & 87 make continuity & if so then each 87 on the relays should be going out to each respective hi/low beam. EDIT you have the wire from the high beams going rearward to 87 on one relay and the wire from the low beams going rearward to 87 on the other relay correct? Batt power to 30 on both. 85 is grounded on both and 86 on one relay gets fire from the high beam dimmer switch wire and 86 on the other relay gets fire from the low beam dimmer switch wire?
Re: Relay wiring problem [Re: MadMatt] #1402945
03/16/13 02:27 PM
03/16/13 02:27 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Re: Relay wiring problem [Re: jbc426] #1402946
03/20/13 01:46 AM
03/20/13 01:46 AM
Southern Oklahoma
wildman340 Offline
wildman340  Offline
Southern Oklahoma
Maybe this will too:
1974 Dodge Dart Sport 340 4 Spd Endless Project 1999 Ram 1500 CC 5.2 5 speed
Re: Relay wiring problem [Re: MadMatt] #1402947
04/13/13 08:06 AM
04/13/13 08:06 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
I saw this post while looking for another one. All the replies assume that the dimmer switch is switching the positive battery polarity. They don't - my 99 Dakota for example, fuses the hot, which goes directly to the headlamp, and switches ground through the dimmer to select low/high beams.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Relay wiring problem [Re: stumpy] #1402948
04/13/13 02:02 PM
04/13/13 02:02 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Bob and I tried the relay idea with the Charger. It didn't work out well.
The low beams came on. The H/L doors opened...But the doors would not close nor the low beams shut off with the switch, UNLESS the high beams were clicked on.
Sometimes the headlight doors would open and close when you turn the ignition/key on.
I ordered a new harness from Evans wiring. The goal of using relays was to have safer power to the lights. The new harness at least puts me back to a stock UN molested condition.
