Relay wiring problem
#1402934
03/15/13 08:57 PM
03/15/13 08:57 PM
Posts: 730 Nampa, ID
MadMatt
Nampa, ID
I am trying to wire in relays to my headlight system and have a problem that is stumping me. With the relays wired in everything is fine with the lights off, fine with the park lights on, but when I switch on the headlights I get no headlights and my voltmeter drops from 15 volts to 10 volts with the engine running. I have checked and rechecked the wiring and everything appears to be correct. The only thing I found which seems weird to me is that with the relays just sitting on the bench they have continuity between the coil ground (terminal 85) and the relay trigger coil feed (terminal 86). Is this normal?? Could I have 2 brand new relays that are both defective? My knowledge of wiring is very basic, so ANY help or suggestions are appreciated!
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Relay wiring problem
[Re: MadMatt]
#1402935
03/15/13 09:13 PM
03/15/13 09:13 PM
RapidRobert
I think you want the original wire to the headlights to go to the coil in (86) & the other end of that circuit (coil ground (85) to ground & the 2 other terminals one of them is connected to the headlights and the other one is connected to the power source (batt or alt) & when 86 is energized from the headlight switch & therefore groundes that circuit thru 85 that it connects the other 2 terminals (headlights/alt or batt) to each other. Someone will chime in with more detailed help
[Re: MadMatt]
#1402942
03/16/13 01:05 PM
03/16/13 01:05 PM
RapidRobert
I'm assuming you have 1 relay for both hi/low beams. I'd think if the headlight power wire TO the dimmer switch is connected instead to 85 & 86 is permanently grounded and 30 is connected to the battery & 87 is connected to the upstream side of the dimmer switch where the headlight power in wire originally was connected to, that you'd be good. On a related note I would highly suggest powering "30" from the alt rather than the battery
[Re: stumpy]
#1402948
04/13/13 02:02 PM
04/13/13 02:02 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Bob and I tried the relay idea with the Charger. It didn't work out well. The low beams came on. The H/L doors opened...But the doors would not close nor the low beams shut off with the switch, UNLESS the high beams were clicked on. Sometimes the headlight doors would open and close when you turn the ignition/key on. I ordered a new harness from Evans wiring. The goal of using relays was to have safer power to the lights. The new harness at least puts me back to a stock UN molested condition.
