Poweglide racers, what fluid do you like? #1402811
03/15/13 03:39 PM
03/15/13 03:39 PM
Cab_Burge Offline OP
I recently bought a Mikes Powerglide Monster Glide with a Contintental 9 inch race converter,I don't have any real world expereince with them, how often do you guys change the fluids and which type flids do you like? BTW, the car weighs around 2500 lbs wet and the motor makes 687 HP, 5.13 gears in the rear with 17x33x15 tires that are right at 104 inches circumference Thanks in advance
Re: Poweglide racers, what fluid do you like? [Re: Cab_Burge] #1402812
03/15/13 03:46 PM
03/15/13 03:46 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
Most often I change fluid when either trans or convertor need service. If not I go 2 seasons with no problems. I buy Napa or Car Quest DexIII and usually add a 2qts of TypeF to the mix.
Re: Poweglide racers, what fluid do you like? [Re: MegaDart] #1402813
03/15/13 04:12 PM
03/15/13 04:12 PM
sg66mopar Offline
sg66mopar  Offline
Cab, I use straight type F. Lately it's been Valvoline or Carquest. The local Carquest guys tell me their brand is made by Valvoline to exactly the same specs.
I used to get a couple seasons but now with the bigger motor and high stall it can be a lot less. The more you stand on the converter, the less life you'll see. Of course you already know that.
If I'm mostly bracket racing I tame it down on the line and the fluid lives a long time.
I'f I'm mostly SG racing the fluid gets nasty a LOT faster.
I put on a big B&M Super Cooler with a 10", 1000 cfm fan, I think early last year, and it made a huge difference.
With my smaller cooler and no fan, in SG trim I was getting 4 passes!
Re: Poweglide racers, what fluid do you like? [Re: MegaDart] #1402814
03/15/13 04:33 PM
03/15/13 04:33 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
Walmart or the cheapest type F around
home of the
Sox and Martin Hemi Duster
Re: Poweglide racers, what fluid do you like? [Re: HEMIFRED] #1402815
03/15/13 05:03 PM
03/15/13 05:03 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
B&M the blue fluid type F,the trans & converter runs a lots cooler.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Poweglide racers, what fluid do you like? [Re: MRMOPAR622] #1402816
03/15/13 05:07 PM
03/15/13 05:07 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Walmart store brand. Don't see any difference in wear, heat, or performance.
If I was happy with the converter and saw no need to make a change for a while I might go with something better. But, when constantly changing gearsets or converters trying to find some more ET just could not justify paying twice as much.
Leon
Re: Poweglide racers, what fluid do you like? [Re: Cab_Burge] #1402817
03/15/13 05:07 PM
03/15/13 05:07 PM
MN
hemidup Offline
hemidup  Offline
MN
If it were me, I'd just bring it to my closest Chevy dealer and let them deal with it. I think I can find a discount coupon for ya. All ya gotta do is pay postage and it's yours.
Sorry....I just had to.
Jerry Williams.
Re: Poweglide racers, what fluid do you like? [Re: HEMIFRED] #1402818
03/15/13 06:16 PM
03/15/13 06:16 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
Walmart or the cheapest dexron around
fixed
Re: Poweglide racers, what fluid do you like? [Re: Cab_Burge] #1402819
03/15/13 06:29 PM
03/15/13 06:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In my brothers altered we run cheapo type F .. works great
Re: Poweglide racers, what fluid do you like? [Re: MR_P_BODY] #1402820
03/16/13 12:43 PM
03/16/13 12:43 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I don't run cheap oil in my engines or transmissions,a lot of Hi $$$ parts in both and after spending all that $$$ don't want to ruin or shorten the life of them by trying to save a couple of $$$ on the oil/fluid.But I see a lot of people who do use the el-cheap-o oil/fluid and save $$$ and say it works just as well.Money saved on oil/fluid means more $$$ to put some where else on the car.So I'm not saying which is "RIGHT" or which is "WRONG" just wondering which method/way is the best.
Re: Poweglide racers, what fluid do you like? [Re: MRMOPAR622] #1402821
03/16/13 01:35 PM
03/16/13 01:35 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Mobil1 here..
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Poweglide racers, what fluid do you like? [Re: Eric] #1402822
03/16/13 02:19 PM
03/16/13 02:19 PM
Denison,Ia.
Cuda367 Offline
Cuda367  Offline
Denison,Ia.
Hughes recomends or told us to use castrol type F a few years back. It seems to take the heat a little better than Valvoline or Napa which is the same.
Re: Poweglide racers, what fluid do you like? [Re: Cab_Burge] #1402823
03/16/13 02:53 PM
03/16/13 02:53 PM
Lehigh Acres, Florida
rickstershemi Offline
good ole Pennzoil dexron/mercon....ati-proglide
Rickster
Re: Poweglide racers, what fluid do you like? [Re: rickstershemi] #1402824
03/16/13 03:10 PM
03/16/13 03:10 PM
Any one using Mikes Transmission Powerglide fluid? I talked to him about my converter spacing and the fluid to use in his trannys and he said to use his stuff, $95.00 for 2.5 gallons plus shipping He said it has additives to make it stick on the expensive parts instead of draining off like stock tranny fluids do when a tranny sits a long time bewteen usages, like most drag cars do How about tractor or hydraulic fluids also? I'm not looking to rediscover what is good and what is not,just what is good and what works good
Re: Poweglide racers, what fluid do you like? [Re: Cab_Burge] #1402825
03/16/13 03:47 PM
03/16/13 03:47 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Amsoil Supershift
Re: Poweglide racers, what fluid do you like? [Re: Cab_Burge] #1402826
03/16/13 05:22 PM
03/16/13 05:22 PM
iowa
wesw Offline
wesw  Offline
iowa
We use AW32 hydraulic fluid in our glide. I haven't had no problems with it ever. JW GLIDE
598 ci predator
Re: Poweglide racers, what fluid do you like? [Re: wesw] #1402827
03/16/13 07:36 PM
03/16/13 07:36 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mobil 1 here and I put a lot of laps on the car every year. Mostly pro tree .90 racing.
Re: Poweglide racers, what fluid do you like? [Re: Cab_Burge] #1402828
03/16/13 09:08 PM
03/16/13 09:08 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
F glide and 727.
Re: Poweglide racers, what fluid do you like? [Re: 540dust] #1402829
03/16/13 10:10 PM
03/16/13 10:10 PM
PA
moparacer Offline
moparacer  Offline
PA
F always works good for me.
I have used hydraulic oil too with no problems.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Poweglide racers, what fluid do you like? [Re: moparacer] #1402830
03/16/13 11:02 PM
03/16/13 11:02 PM
BigFish69 Offline
BigFish69  Offline
Amsoil syn.
