440 block but no caps #1402654
03/15/13 08:54 AM
03/15/13 08:54 AM
Loganville GA.
K
kdsmith07 Offline OP
K
Loganville GA.
anybody have experience in buying a block minus caps.looking to buy a 67 440 hp without them.would it be a dumb move money wise trying to machine non matching oe caps?btw,250.00 for the block.standard bore.any comments,opinions and stories welcome.thanks in advance,kent
Re: 440 block but no caps [Re: kdsmith07] #1402655
03/15/13 09:11 AM
03/15/13 09:11 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
How odd...My 505 block started off life as a 67' 440. I couldn't find my main caps either. On a whim, I went ahead and ordered a brand new set from 440Source. I gave them to the machinist and he asked me how much I paid for them because they are the nicest caps he had ever seen for a BB Mopar
http://store.440source.com/Billet-Steel-Main-Caps-Set-of-5/productinfo/200-1039/
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: 440 block but no caps [Re: Pyper70] #1402656
03/15/13 09:39 AM
03/15/13 09:39 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what he said, not to the quality but you can buy aftermarket caps and have the machine shop set them up. AND FWIW if you ever break a 8.75 (including end caps) make sure you have them machined too...AMHIK.
Coming soon!!!!
Re: 440 block but no caps [Re: kdsmith07] #1402657
03/15/13 10:34 AM
03/15/13 10:34 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I've used caps off of different blocks before, along with line honing at least. I would look at the 5 saddles for signs of nasty bearing spin etc. Oh, and try to get the thing for less cash if you can too.
Re: 440 block but no caps [Re: buildanother] #1402658
03/15/13 12:10 PM
03/15/13 12:10 PM
Minnesota
peabodyracing Offline
Minnesota
It's been too many years, but as I recall you simply have a machine shop align bore them installed on the block. Believe they cut a bit off the bottom of the caps before installing. Pretty standard process.
I should say I hope it is still a standard process as the original HP block I got with my 69 RR came in the same condition as the one you're looking at and I have hung onto another set of caps to use.
Lead, follow or get the hell out of the way
Re: 440 block but no caps [Re: kdsmith07] #1402659
03/15/13 12:32 PM
03/15/13 12:32 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Just for a comparison of labor/machining costs, align boring/hone to fit aftermarket caps is around $450+ or more, plus the cost of the caps when I did the BCR aluminum caps with girdle on my 400 block. If you had a stock block with original caps, align hone is only around $100.
My point is, if you don't need the aftermarket caps for your application, you can save money using a block with the stock caps even if it is a few $$$ more than a block without the main caps.
Re: 440 block but no caps [Re: kdsmith07] #1402660
03/15/13 01:11 PM
03/15/13 01:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That's a lot of money for a block with no caps . Is this something you want because of date codes ? You'll be close to $800 into it by the time you are done putting caps on it if you go with aftermarket caps.
Re: 440 block but no caps [Re: JohnRR] #1402661
03/15/13 03:11 PM
03/15/13 03:11 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
If you get it and can't find a stock set of caps I have a 68 HP block I will be scraping soon. 50 dollars plus shipping for the caps.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 440 block but no caps [Re: kdsmith07] #1402662
03/15/13 05:13 PM
03/15/13 05:13 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I've done it with just a line hone always do that anyways!
course 5 years later I found the box with the right caps in!
Re: 440 block but no caps [Re: Dodgem] #1402663
03/15/13 08:25 PM
03/15/13 08:25 PM
Loganville GA.
K
K
Loganville GA.
thanks guys for all the replies.i'm still up in the air about it.john,i don't need a 67 i just saw it on c/l.looking for a cheap block to mess around with.i found a 440 block w/caps for 150.00 and it's a 77 bored .040.i was told buy a few local "experts" that are smarter than me i think,not to buy it as your're not supposed to bore a thin wall 77 over .030.is that correct?should have come here first but i don't like feeling stupid.lol.thanks again in advance
Re: 440 block but no caps [Re: kdsmith07] #1402664
03/15/13 08:35 PM
03/15/13 08:35 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Fairly common to go 0.055" over to a 4.375" bore.
The "thin wall" myth has been debunked years ago.
Re: 440 block but no caps [Re: 451Mopar] #1402665
03/15/13 08:41 PM
03/15/13 08:41 PM
Loganville GA.
K
K
Loganville GA.
ok,thanks.think i'll go back and buy that one too.
Re: 440 block but no caps [Re: kdsmith07] #1402666
03/15/13 08:47 PM
03/15/13 08:47 PM
PA.
"Little"John
"Little"John
PA.
Here's some real good reading when you get a chance.
http://www.440source.com/blockinfo.htm
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 440 block but no caps [Re: pittsburghracer] #1402667
03/15/13 09:01 PM
03/15/13 09:01 PM
Loganville GA.
K
K
Loganville GA.
appreciate ya pittracer.think i'll read it now before i buy anything else.lol
Re: 440 block but no caps [Re: kdsmith07] #1402668
03/15/13 09:33 PM
03/15/13 09:33 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I sonic tested all of my blocks and my 77-78 blocks were the best. Earlier ones are mostly good but some were really bad.
Re: 440 block but no caps [Re: fastmark] #1402669
03/16/13 12:49 AM
03/16/13 12:49 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Thin wall is a myth. For 150 bucks I would scoop up the 77 block.
Re: 440 block but no caps [Re: 451Mopar] #1402670
03/16/13 06:04 AM
03/16/13 06:04 AM
Same as 451Mopar, I bought the BCR girdle and aluminum caps. They look very nice. Bought them for a 400 with the extra meat. Don't mind spending a little extra on it.
Re: 440 block but no caps #1402671
03/16/13 06:31 AM
03/16/13 06:31 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
440 blocks are not hard to find. I would just be patient and find a standard bore motor with caps. I have never paid more than a few hundred bucks for a complete one.
Re: 440 block but no caps [Re: viperblue72] #1402672
03/16/13 07:58 AM
03/16/13 07:58 AM
Loganville GA.
K
K
Loganville GA.
thanks for all the info.knowledge is king.
