Need Help with matching camshaft and valve springs #1402475
03/14/13 05:11 PM
03/14/13 05:11 PM
Badge Offline OP
Badge  Offline OP
I have a 360 small block. I am going to install a purple shaft camshaft P 4120233 AC hydraulic flat tappet .508/.508 @ 292/292.
I have a new set of Manley dual valves springs. Seat 115 lbs @ 1.80,
Open 310 lbs @ 1.25. Are they to much spring for this cam? Thanks.
Re: Need Help with matching camshaft and valve springs [Re: Badge] #1402476
03/14/13 05:14 PM
03/14/13 05:14 PM
Guitar Jones Offline
Are they really duals or a single spring with a damper? But no, I don't think that's too much spring.
Re: Need Help with matching camshaft and valve springs [Re: Guitar Jones] #1402477
03/14/13 06:30 PM
03/14/13 06:30 PM
dogdays Offline
dogdays  Offline
Important question: What is your spring installed height? I'd be surprised if you had all of 1.80" on a stock smallblock head. I've measured between 1.6 and 1.625 on mine.
So 1.625 - 0.060 for coil bind -0.508 lift equals 1.057 maximum spring solid or coil bound height. Anything more than that and you're breaking things.
Another thing, your spring has a rate of 355 lb/in, the reduction of height puts the seat pressure at 177 lb. That's quite a bit.
I'm not as experienced as many others, but IMHO going high-lift on an LA motor takes some careful juggling of spring parameters.
R.
Re: Need Help with matching camshaft and valve springs [Re: dogdays] #1402478
03/14/13 07:34 PM
03/14/13 07:34 PM
Badge Offline OP
Badge  Offline OP
Good point. I have not measured the existing springs for installed height.
