I have a 360 small block. I am going to install a purple shaft camshaft P 4120233 AC hydraulic flat tappet .508/.508 @ 292/292. I have a new set of Manley dual valves springs. Seat 115 lbs @ 1.80, Open 310 lbs @ 1.25. Are they to much spring for this cam? Thanks.
Are they really duals or a single spring with a damper? But no, I don't think that's too much spring.
