Re: 70-71 reproduction BB 6 qt oil pan
[Re: mickm]
#1402007
03/13/13 06:22 PM
03/13/13 06:22 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Just a suggestion, Milodon makes a repo Hemi pan, it's a little nicer than most, the dies are crisp so the metal is straighter, & the baffles are tig welded... painted very few would know it wasn't a Mopar pan.... http://www.summitracing.com/parts/mil-30761
[Re: ProSport]
#1402009
03/13/13 06:38 PM
03/13/13 06:38 PM
Posts: 343 S.E.Mich
drew72
S.E.Mich
How well do these 6 qt pans work with a 600hp street/strip engine(low deck stroker)? Just looking for extra ground clearance.
I don't think the oil pan cares how much hp your engine creates. Same as a stock hemi pan.
[Re: screamindriver]
#1402015
03/14/13 02:18 AM
03/14/13 02:18 AM
Posts: 43,298 Bend,OR USA
Cab_Burge
Is anyone making an accurate dipstick for the 6qt pan??? The current MP chrome stick is way off using that pan..
Probally not I use the Mopar chrome one and cut the tube down to calibrate the dipstick, make sure the motor is level and run the motor first, drain the oil out of it and fill the pan up with 5 quarts, cut the dipstick tube down, a little at a time, until the oil dipstrick shows one quart low, stop cutting there an add one quart, you should be golden then BTW, I use a tubing cutter with a stock SB hydraulic pushrod inserted in the tube to avoid crimping the tube down while trimming it
#1402016
03/14/13 02:20 AM
03/14/13 02:20 AM
Posts: 4,179 California
mickm
California
the reproduction hemi dipstick is accurate. i use it.
had to bend it to fit the TTI headers, but they give you a good diagram. didn't take me long. it's bigger than 3/16" though, so a 3/16" tubing bender doesn't work too well. i ended up heating mine with a propane torch, much easier!
[Re: Cab_Burge]
#1402017
03/14/13 10:36 AM
03/14/13 10:36 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
Very good tip here , you old guys are pretty smart ...
[Re: Cab_Burge]
#1402018
03/14/13 08:13 PM
03/14/13 08:13 PM
Posts: 821 NW Ohio
6pkaar
NW Ohio
Why can't you start with 6 quarts, measure how far off the oil level is off the full mark on the dipstick and cut that much off the tube?
[Re: 6pkaar]
#1402019
03/14/13 09:16 PM
03/14/13 09:16 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
And here's my last ordeal using the MP chrome dipstick assy with the 6 qt pan... The tube's too short !!! ...Yep, 4 1/2 qts it reads full...So you would actually need to shorten the stick{?}not the tube for the correct reading...And I did'nt do it{yet} I just deal with it... Which brings us to the next step.... Here's what I've come up with so far so if it's wrong please feel free to add too/correct whatever info/assumptions are'nt correct...
The supposed NOS mopar original 70-71 BB for B and E body{fits all BB except hemi} tube part# 3462415 is listed as 17 5/8 long...How much of that is below the block seating ridge I don't know... The matching mopar dipstick for that tube, part# 3698500 is 27 3/8 long...So this would lead me to believe the oil level is ending up the same height{relative to the block} wether you're using the standard or 6 qt pan...
I don't have the set or I'd assemble them and come up with a measurement from the block seating ridge to the full/add marks on the stick to take the guesswork out of this mess for future reference..
And incidently the chrome mp stick tube is 23 inches long and at first glance at the numbers would indicate it being WAY off...But supposedly the shorter chrome tube/stick assembly was a matched set to maintain the same oil level markings which obviously is'nt the case be it poor quality control or whatever...
Right now in 2013 that NOS dipstick/tube is worth 50-100 bucks or more if the guy that has it dipped it in gold for some reason so it does'nt make sense to buy one just to bend it up if you've got headers which leaves everyone needing something accurate no matter how you call it... I have'nt tried the hemi stick so I can't comment on that one.. OK I'm out of breath..
#1402022
03/15/13 01:29 AM
03/15/13 01:29 AM
Cab_Burge
