Best intake for a 440 #1400965
03/11/13 07:45 PM
03/11/13 07:45 PM
Minneapolis, MN
moparguy Offline OP
moparguy  Offline OP
Minneapolis, MN
I am sure this has been asked many times, but I would like to ask what is thought when paired with my engine.
The specs:
440 .030 over
forged crank
stock rods
speedpro forged pistons 2295f (.140 dome)
down .055 in the hole
86 CC heads with pocket porting 2.14/1.88 valves
Comp XE285HL cam
We figured that it would be roughly 10.2:1 compression the cam is a .545 lift hydraulic. I had a few people recommend using either a Victor intake or a M1 intake. Does anybody have any recommendations on either of those or of any better intakes for this combo?
Re: Best intake for a 440 [Re: moparguy] #1400966
03/11/13 07:51 PM
03/11/13 07:51 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Do you race the car,or street drive it? A performer RPM is a good street/ strip intake for that combination . If your car is light,has a lot of gear,etc. I would use the Victor style.
Probably be more help with a better description of thwarted car and its use
Keith
Re: Best intake for a 440 [Re: Dunnuck Racing] #1400967
03/11/13 08:01 PM
03/11/13 08:01 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Keith
I agree. The Holley Street Dominator may also work good with it depending on the weight , gear and so on. Ron
Re: Best intake for a 440 [Re: 383man] #1400968
03/11/13 08:12 PM
03/11/13 08:12 PM
Minneapolis, MN
moparguy Offline OP
moparguy  Offline OP
Minneapolis, MN
I suppose that would help. its in a 74 dodge charger. and has a 3.55 SG but i will be swapping that out with a 4.10 soon here. The car is a street/strip car, and is quite portly at around 4k pounds.
I also do have a old Weiand 7500 intake here if you think that may work for my combo.
Re: Best intake for a 440 [Re: moparguy] #1400969
03/11/13 08:22 PM
03/11/13 08:22 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I would go with the Eddy Performer RPM on your combo. Just make sure it will fit under your hood if you do. Ron
Re: Best intake for a 440 [Re: moparguy] #1400970
03/11/13 08:26 PM
03/11/13 08:26 PM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
HELLO WE NEED MORE INFO SO WE CAN HELP YOU, WHAT HEADS IRON OR ALUM, HEADERS OR STOCK EXHAUST, YOUR SRALL, WHAT REAR GEAR RATIO,WHAT CARBURETOR, A DUAL PLANE WILL HELP YOUR LOW IN TORQUE ,A SINGLE PLANE WILL HELP YOUR TOP IN TORQUE. MORE INFO PLEASE
Re: Best intake for a 440 [Re: mosweethemi] #1400971
03/11/13 08:32 PM
03/11/13 08:32 PM
Minneapolis, MN
moparguy Offline OP
moparguy  Offline OP
Minneapolis, MN
the heads are 452 stock heads with some porting porting and 2.14/1.81 valves. I have HP exhaust manifolds with 3" exhaust. 2800 stall converter. the rear end has a 3.55 SG in it now but i will be changing to a 4.10. the carb I have is a eddy eps 800 cfm
Re: Best intake for a 440 [Re: moparguy] #1400972
03/11/13 09:55 PM
03/11/13 09:55 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
RPM or S/D. or you could go for a nice 3x2....
Coming soon!!!!
Re: Best intake for a 440 [Re: Mr.Yuck] #1400973
03/11/13 10:37 PM
03/11/13 10:37 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
with ya!!
If you plug in your car weight/converter stall/carb size/cam factors:
S/D - Moderate Street/Strip (Great all-around performance, especially with a TQ)
RPM- Sharper Street Performance Good basic Strip manifold.
Six pack - Great Street/Strip setup, added airflow
accomodates bigger hydraulics and small solids. Just have to "dial-in" the jets and secondary barrel(s) timing.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Best intake for a 440 [Re: Mr.Yuck] #1400974
03/11/13 11:18 PM
03/11/13 11:18 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yea forgot about the 6pk setup as that would work nice with the right tune on it. Ron
Re: Best intake for a 440 [Re: 383man] #1400975
03/12/13 12:01 AM
03/12/13 12:01 AM
Minneapolis, MN
moparguy Offline OP
moparguy  Offline OP
Minneapolis, MN
What about the edelbrock low rise dual four barrel set ups? the 6 pack setup is abit too pricy for what I have seen.
Re: Best intake for a 440 [Re: moparguy] #1400976
03/12/13 12:08 AM
03/12/13 12:08 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I had the old Edelbrock TM7 intake on my 440, stock heads, 10.5 compression. put on the Victor and it slowed the car down .15 in the quarter. I changed back and picked it back up. To big of a intake for the engine I had.
Re: Best intake for a 440 [Re: moparguy] #1400977
03/12/13 12:12 AM
03/12/13 12:12 AM
Kansas
BEINGmeISaCRIME Offline
Kansas
I don't like the xe285hl cam. Have one in my 440 with 10.6 compression, aluminum heads, and aluminum single plane intake. Installed at comps specs (106 icl) it's done at 5400 rpm. The comp valve train will allow it to rev up above 6 without valve float. I suppose if you retarded the cam timing a couple of degrees you could raise the peak hp rpm number. My engine on the demo made 500 ft lbs of torque from 3900-4800 and 475 peak hp at 5400. It's also going into a 72 charger.
Re: Best intake for a 440 [Re: HYPER8oSoNic] #1400978
03/12/13 12:43 AM
03/12/13 12:43 AM
OH, USA
Torred Offline
Torred  Offline
OH, USA
with ya!!
RPM- Sharper Street Performance Good basic Strip manifold, add a 950 holley and look out
Re: Best intake for a 440 [Re: Torred] #1400979
03/12/13 02:38 AM
03/12/13 02:38 AM
Eastern WA
P
ProStock1320 Offline
P
Eastern WA
So, how about an Indy dual plane 1x4? Not enough engine for it? Is the Indy part over-hyped? Don't want a political discussion on Indy, just throwin it out there.
Re: Best intake for a 440 [Re: ProStock1320] #1400980
03/12/13 03:45 AM
03/12/13 03:45 AM
Kansas
Kansas
I was wondering the same. I read somewhere it out flows the edelbrock. The thing with the Indy that scares me away is the price. But I suppose you do get what ya pay for.
Re: Best intake for a 440 [Re: ProStock1320] #1400981
03/12/13 04:02 AM
03/12/13 04:02 AM
Cab_Burge Online work
Cab_Burge  Online Work
Does Indy make that manifold in 440 port sizes? I was told they don't OP, go get the Eddy Performer RPM intake and 850 CFM or Bigger Holley doulble pumper, you won't be sorry As far as the Eddy dual four intake with dual Eddy or Carter carbs they aren't as responsive or as nice to drive as the single carb is on a good intake like the Eddy Performer RPM are
Re: Best intake for a 440 [Re: moparguy] #1400982
03/12/13 06:20 AM
03/12/13 06:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Since you have a low stall conv... being that way
you need to make all the torque you can make at a
low RPM to move the weight.... go with the RPM...
your cam wont support high rpm anyways so think low
rpm.... also being that its mostly street I would keep
the 3.55 in it for a while to check out the engine
changes... then if you want change the gear
Re: Best intake for a 440 [Re: MR_P_BODY] #1400983
03/12/13 09:33 AM
03/12/13 09:33 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Eddy performer RPM ..no question !!
Re: Best intake for a 440 [Re: Cab_Burge] #1400984
03/12/13 09:41 AM
03/12/13 09:41 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The 440 port size is the only size they make.
