valve body shift kits applications/modifications #1400911
03/11/13 01:30 PM
03/11/13 01:30 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hello All,
Was curious on the complexity/difficult(ness) of performing the modifications of a 727 valve body with a, for example, TransGo TF-1 kit. I'm looking to tackle something like this on a stock 727 valve body. Any videos out there? From the looks of it, the kits are very simple with minimal parts..
Thanks.
Troy
Houston Mopar Connection Club
Re: valve body shift kits applications/modifications [Re: hemi68charger] #1400912
03/11/13 06:38 PM
03/11/13 06:38 PM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
Although it looks simple, the best kits can be very complex. The best kits require drilling holes in parts etc. I had enough problems, even having the trans builders do the work, with kits that I finally added it up. You are money ahead to call Turbo Action, ask for thier manual/auto valve body and install the whole thing! Believe me, they have done thier homework and it results in the best shifting 727 I have ever owned. From your screen name, it sounds like you have a very nice and expensive car. A "trans kit" caused me to have to pull and replace a 727 after the car was together, painted etc. Do you really want to know the cost of a "kit" vs. a valve body?
Re: valve body shift kits applications/modifications [Re: hemi68charger] #1400913
03/11/13 07:43 PM
03/11/13 07:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you have reasonable mechanical skills and can read, you can install the Transgo kit...unfortunately their instructions are less intuitive than they were years ago.
I would choose a reprogramming kit over a valve body because the kit deals with the valve body and the case whereas most valve bodies don't address the shortcomings in the servos.
