Diff's between pre-'70 and '70-up alternators? #14000
01/05/05 03:20 PM
01/05/05 03:20 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Here's my "I'm a big dummy" question for the day (or the hour, depending upon how things are going ):
Are there any functional differences between a "round back" alternator for a '69-earlier and '70-later? Seems like I've seen stuff re: differences in the charging systems (voltage regulators and???) for those year ranges, yet I see Mancini offers a couple of "repro round-back" alternators that are listed to cover all applications prior to 1975.
Re: Diff's between pre-'70 and '70-up alternators? [Re: BradH] #14001
01/05/05 03:24 PM
01/05/05 03:24 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
The main difference is that the early alternator, has one field wire, while the newer has 2.
Some think that the newer alt actually has 2 fields, while the older only one. This is false.
www.davesmopar.com/techreg.htm
The newer ones start to get into higher amperage ratings, than the older ones too.
Re: Diff's between pre-'70 and '70-up alternators? [Re: BradH] #14002
01/05/05 03:38 PM
01/05/05 03:38 PM
Fort DODGE, Ioway
O
origcharger Offline
origcharger  Offline
O
Fort DODGE, Ioway
The pre 70s ground one terminal of the field at the alternator.
The 70s and newer do not have the one field terminal grounded as the voltage regulator provides a variable ground to control output.
A 70s and newer alternator can be easily adapted to work with a pre 70s charging system by simply grounding one field terminal. So if someone is selling an alternator to work on both systems they are likely providing a short ground strap or wire with instructions.
MOPARTS ALERT!: Chris Pugh aka gabodyman of Dalton, Georgia, cashed my $140 money order on 4-16-02 never sent parts. On 3-19-07 he agreed to return my money; "april 9, it will be in the mail by that date""will do as promised. chris" Still no parts and no money!
Re: Diff's between pre-'70 and '70-up alternators? [Re: origcharger] #14003
01/05/05 05:07 PM
01/05/05 05:07 PM
Belle Mead, NJ
65Frank Offline
super street
65Frank  Offline
super street
Belle Mead, NJ
I think you can also use pre'70 brushes (one of which grounds to the case) in a post '70 alt. Does the same thing as the jumper wire. I'm thinking about trying this on a spare alt when I get a chance.
I'm also running an old style (pre'70) electronic voltage regulator, which is cool and should work well with the new alt.
Re: Diff's between pre-'70 and '70-up alternators? [Re: 65Frank] #14004
01/05/05 05:22 PM
01/05/05 05:22 PM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
Amazing how an unchallenged lie can become the absolute truth.
Re: Diff's between pre-'70 and '70-up alternators? [Re: BradH] #14005
01/05/05 07:40 PM
01/05/05 07:40 PM
MO/near Independence& Liberty ...
notnxs383 Offline
notnxs383  Offline
nice... thanks beepbeep.
It don't mean nothing..the words that you say! 65 & 66 Dart, 67 notch, 90 RamVan, 91 Rollback 5.9 '70 SE Challenger 383L matchin' ... but another man never would have let her go.. I stashed the bill in my shirt.
