'71 GTX Sail Panels #1400399
03/10/13 06:39 PM
03/10/13 06:39 PM
On the open road
Hrtbkr Online content OP
Hrtbkr  Online Content OP
On the open road
Hi. I'm replacing the sail panels in my GTX. The new ones from REM are flat and have two faced tape stuck to the top and bottom of the backing on all sides. The perforated material is about 1/2 bigger than the backing material.
1) Is there a good way to form a curve in the backing material? Will the trim force it into shape?
2) Should I wrap the perforated over the top and bottom of the backing?
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: '71 GTX Sail Panels [Re: Hrtbkr] #1400400
03/10/13 07:33 PM
03/10/13 07:33 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I hate to tell you this, but 71 sail panels never came with head liner material on them.There is a metal hook that popes in to the sheet metal.Those sail panels are completely wrong,and nobody make correct ones.
Re: '71 GTX Sail Panels [Re: 71birdJ68] #1400401
03/10/13 09:26 PM
03/10/13 09:26 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
they originally were covered in a paper like substance almost like the package trays. what I ended up doing is taking my original, stained up ratty ones and sanding them down and put wall paper over them and dyed it my interior color. I bought some plain white wall paper with a real slight texture from my local menards.. turned out pretty close to the originals and is a heckuva lot more close than the headliner material.
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: '71 GTX Sail Panels [Re: Hrtbkr] #1400402
03/11/13 12:49 AM
03/11/13 12:49 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Don't know.
Mine did.
That's what I did.
To add to what subsequent posters said, no match. But I liked the old sail panels less than the new ones, so stuck with the new ones. Rear window trim and side glass trim did a fairly decent job (at least on my '72 RR) of holding replacements in place, and I liked the idea of a material match to the headliner (I used leftover headliner material to cover them) rather than having one more different texture/pattern on the interior (i.e., seats, door panels, dash pad, carpet, dash, package tray, etc.)
Re: '71 GTX Sail Panels [Re: Hrtbkr] #1400403
03/11/13 01:39 AM
03/11/13 01:39 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Material covered SP's may not be 'correct', but they sure do add a nice touch...
If yer not playing the OEM game...
Re: '71 GTX Sail Panels [Re: RSNOMO] #1400404
03/11/13 09:23 AM
03/11/13 09:23 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Up close pic of originals
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: '71 GTX Sail Panels [Re: Hrtbkr] #1400405
03/12/13 12:13 AM
03/12/13 12:13 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Also one more thing. The trunk mats that are on the market now are ALL wrong. they look like crap compared to the original.
