727 experts - #1400231
03/10/13 02:44 PM
03/10/13 02:44 PM
beentheredonethat
AverageJoe Offline OP
beentheredonethat
What are these two holes plugged with silicone ? The rebuilder seemed to like the stuff ..........
Re: 727 experts - [Re: AverageJoe] #1400232
03/10/13 02:45 PM
03/10/13 02:45 PM
beentheredonethat
beentheredonethat
Re: 727 experts - [Re: AverageJoe] #1400233
03/10/13 02:52 PM
03/10/13 02:52 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the pins that the band levers ride on go in those holes..there is a threaded plug sealing the hole..looks like the rtv is insurance against a leak.
Tony
70 AARCuda Vitamin C
Re: 727 experts - [Re: 70AARcuda] #1400234
03/10/13 05:45 PM
03/10/13 05:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Looks like the builder of that trans thought he needed lots of silicone "insurance"...whats the pan look like?
Re: 727 experts - [Re: John_Kunkel] #1400235
03/12/13 07:34 PM
03/12/13 07:34 PM
beentheredonethat
beentheredonethat
Pan contents looked fine - slight bit of "metal dust/sludge" nothing unusual. Pan leaked like a seive, will be upgrading to the new gasket - also filler tube base leaked - need to address best way (new O ring and sealant ?) .........
Re: 727 experts - [Re: AverageJoe] #1400236
03/12/13 07:40 PM
03/12/13 07:40 PM
What worked for me on that issue was when I had the pan off was to clean the hole with brake kleen so the black RTV would adhere. Not sure if you need a regular O ring or a square cut one
Re: 727 experts - [Re: RapidRobert] #1400237
03/13/13 12:49 AM
03/13/13 12:49 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's a regular o ring , as said clean the hole good , put a big bead of RTV below the oring , install the tube and let the RTV cure overnight.
Re: 727 experts - [Re: JohnRR] #1400238
03/13/13 11:38 AM
03/13/13 11:38 AM
Thank you double R
