Re: 727 experts -
[Re: AverageJoe]
#1400233
03/10/13 02:52 PM
03/10/13 02:52 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
the pins that the band levers ride on go in those holes..there is a threaded plug sealing the hole..looks like the rtv is insurance against a leak.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: 727 experts -
[Re: 70AARcuda]
#1400234
03/10/13 05:45 PM
03/10/13 05:45 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Looks like the builder of that trans thought he needed lots of silicone "insurance"...whats the pan look like?
Re: 727 experts -
[Re: RapidRobert]
#1400237
03/13/13 12:49 AM
03/13/13 12:49 AM
Posts: 75,015 U.S.S.A.
JohnRR
U.S.S.A.
also filler tube base leaked - need to address best way (new O ring and sealant ?)
What worked for me on that issue was when I had the pan off was to clean the hole with brake kleen so the black RTV would adhere. Not sure if you need a regular O ring or a square cut one
It's a regular o ring , as said clean the hole good , put a big bead of RTV below the oring , install the tube and let the RTV cure overnight.
